Rate My Alignment
zw470
McFly
PA
'21 JLR
This is after 2" spacer front and rear with TeraFlex Sport front LCAs.
Jeep Wrangler JL Rate My Alignment mm9IK3J
Wish I would have thought to have it checked before the lift went on.
firedude
Bret
AZ
2022 Rubicon XR 392 Stingray
Retired firefighter
Those caster numbers look suspect. I would think that is wrong. Probably closer to 6 or less. I hate to say it but a lot of alignment shops do not have good techs working for them. Unless you have adjustable control arms, they are just setting toe. They still charge full price though.
How does the jeep ride?
mwilk012
2018 Ocean Blue JLU Rubicon
Service
The Teraflex Sport lower arms are fixed, any idea what their length is? Those caster numbers are very high.
Also your steering wheel is either off center, or was off center when these measurements were taken.
zw470
zw470
McFly
PA
'21 JLR
Slight pull to the right, but it's had that since the STT Pros went on. May have gotten worse with the lift, but it could also be placebo effect.
24-5/8" according to TeraFlex. How can you tell the steering wheel is off by the numbers there?
mwilk012
Service
Total toe is in spec but both sides are out of spec.
zw470
zw470
McFly
PA
'21 JLR
So if I'm reading the numbers correctly, the wheels are pointing too far to the left and I need to adjust the drag link to be slightly longer to pull both of them back to the right?
mwilk012
Service
How does it drive? That’s the best analysis to go by.
zw470
zw470
McFly
PA
'21 JLR
Steering wheel is centered but when driving I suppose a slight pull to the right. Which is the opposite of what I pictured in my head with positive toe on the right and negative on the left.
