Racechip GTS (rough idling after update)
Herson
Herson
Michigan
2020 JL Wrangler unlimited rubicon
I have a Racechip GTS installed for over a year without problems. Today the app updated the calibration and now in “race” settings 7 all the dash lights turn on. Check engine light with P2172 code, stability control lights etc. I have to set it to 6 now, but as soon as I place the settings on 7, the problem returns. Has anyone experienced this?
Darryn
Darryn
Philippines
2023 Jeep JLUR
Hi, were you able to solve your problem?
I am currently experiencing the same situation with map 7, the rest of the settings work fine.
Tr4ckD4ys
NY
2025 Jeep Wrangler Rubicon Xtreme 35-inch 2-door, '41 Green
Tech
I am not a customer of racechip but have become unintentionally well versed with piggyback type devices. The code and experiences you guys are describing strongly indicate that the Racechip is losing communication with the CANBus, specifically the MAP sensor data it is connected to, when using Map 7.
Of course, it means for the time being you can’t use Map 7 until Racechip has released an update to the software. It sounds like a bug that is causing this. Are you able to flash back to the previous version?
Herson
Herson
Herson
Michigan
Yes, I called Race Chips and they reverted the update to the previous one and solved it. I just left it there and haven’t updated it since.
