Question on a jl hard top conversion about sccm clock spring
Mangler1
Vince
2019 jl. 04 th
I bought the 3 piece hard top and wiring harness from the dealer. I got the wiring all in until the last piece, the sccm or multi function switch. The original one has 3 plugs and this one has 1. It plugs into one of the slots on the airbag but I have an airbag light. Assuming we got wrong one The dealer ordered another hardtop wiring harness for me and it also came with a 1 wire multifunction switch. The picture shows 3 like mine and my dealer has never done the swap? I read a few threads on here about it. I read one place mopar is labeling the kits wrong. Any advice? I'd like to get it fixed before programming. I don't think the refresh will fix airbag light. I'll include pics of both multi function switches.
Jeep Wrangler JL Question on a jl hard top conversion about sccm clock spring 20220328_165332
Jeep Wrangler JL Question on a jl hard top conversion about sccm clock spring Screenshot_20220330-161551_Chrom
Mangler1
Mangler1
Vince
2019 jl. 04 th
I meant re flash not refresh lol
jlamanske
Jonathan
2021 Wrangler Unlimited Willys
If you have no heated steering wheel it has a different harness also.
CorvZ061
Travis
Amarillo, TX
'24 JLUR 6MT
That is the harness for the steering wheel airbag. How does a 3 piece hardtop require this?
Just a guess, but being that everything is canbus it all talks to each other in some way. But I don't see the relation with a multifunction switch and the airbag.
Mangler1
Mangler1
Vince
2019 jl. 04 th
It's an entire assembly it has the clock spring on the front of it. I think I might have figured it out I have to swap the clock spring.
jaymz
Jay
Inland Empire
2018 Rubicon Unlimited
Looks like the airbag clockspring and MFS switch are an assembly. Hardtop conversion requires new MFS with rear wiper controls.
Redrubi21
21 JL rubicon
I will be doing this as well. Have you figured it out?
Bekser
New Haven, CT
2021 JLR Sarge Green 6MT
Yes I pulled the sccm and swapped the clock spring being careful not to move anything. It's perfect now.
Hello, any problems doing this so far? Also, did you just take to the dealer to have it re-flashed?
fczabala
FL
JLUR; X5
care to share any tips on swapping the clocksprings? dealing with this now, received a sccm with only one wire for the air bag
fczabala
FL
JLUR; X5
nevermind it was easier than I thought
Nitehawk92
Vandalia, Ohio
23 JLU Reign Rubicon 14 Mazda, 22 Hyundia Santa Fe
Retired Air Force Current Civil Service Civilian.
It is a b!tch and $$ to install a hard top on a factory soft top Jeep. If you think you will ever want a hard top, buy it from the factory with the top. Good job getting it done, it is expensive and time consuming...
Crawl Away
Jeremy
DFW
2019 Wrangler Rubicon Unlimited - 1998 TJ Sport
I wouldn’t install the clock spring if the only add was the rear wiper. I can’t even see out my back window with the spare so a clean window isn’t helpful.
