Question for the lifted rubicons with e torque engine
kah.mun.rah
Merenkahre Jr.
Duat
3.6L e-torque, Gamechanger 3.5" on 37's, re-geared to 5.38's. It's got more pick up than stock and cruises 80mph at 16mpg
Be easy on the throttle. 5.38 is a pretty thin ring gear tooth on a Dana 44.
Jtphoto
Thunder Bay ON
I wouldn’t be too worried about 5.38 in a a modern D44. I ran them in my JK for over 150k Klm on 37” Pitbulls and broke axles but no issues with gears. Those gears are still stronger then most axle shafts.
davewald
Bellingham, Washington
www.davewaldrop.com
2021 Wrangler Rubicon
Sort of, kinda retired....mostly
I have had the unique opportunity to drive both engines with the same exact lift and tires because of a fire. Details HERE. Both engines perform(ed) exceptionally well on the road and on trails. I've run the 3.6 on the Rubicon Trail, Moab, and other BoH and local trails as well as 80mph+ on freeways in Idaho and Utah, and it performs very well. As others have said, stop stressing and get what you want.
Bandit59
Tennessee
2021 Jeep Wrangler 4xe
I test drove one today. thinking about it but really wanted the turbo 4. When u went bigger tires. Did you see a performance difference? The v6 seemed sluggish compared to the turbo 4
I have a 3.6 no complaints. It isn’t a 5.7. But hey did not have to pay for a 5.7 either
davered00ss
davered00ss
Canterbury Ct
2018 Wrangler 2 door
You are gonna have to regear a 2.0 for the bigger tires for the same reason. The Turbo makes no difference in the bottom end where the e torque has more power and torque.
Take a look at the Dyno graphs for the two engines. the 2.0 makes loads more torque down low.
Jtphoto
Thunder Bay ON
There
There are no Dyno graphs for the 3.6 e torque which adds +90ftlbs torque at start..
Zandcwhite
Zach
Patterson, ca
2019 jlur
There
There's no dyno graph for it because it happens so low in the rpms it is almost immeasurable. Does the etorque make a slight difference in low throttle take offs on the street? Sure. It's it even noticeable if you get into the throttle even remotely aggressively, especially in 4LO? Not in the slightest. I believe I read it's only active until 1200rpms. Blip the throttle in the slightest and see how quickly you're above that and your etorque is doing nothing. That being said, both jls we've owned have had etorque, I'm not afraid of its longevity at all. It just isn't the major power adder some think it is. If it were, 0-60s for etorque Jeeps should fall about half way between the same non-etorque model and the 4xe that actually adds 150ftlbs throughout the rpm range. They aren't. They are in fact no different than the non-etorque models. At best its enough boost to make up for its added weight.
davered00ss
davered00ss
Canterbury Ct
Went wheeling twice today. Second time was with top And doors off. Lol
davered00ss
davered00ss
Canterbury Ct
Last photo just to show I’m not afraid to send it. ?. That was really not intentional. A little too much gas
davewald
www.davewaldrop.com
I see lots of places to add goodies. Wench, sliders, skids, lights...
davered00ss
davered00ss
Canterbury Ct
Needs tires. the 33's can go on the tacoma. I need 35's or 37"s
davewald
www.davewaldrop.com
35’s are plenty enough for me. Got all these on them
Jeep Wrangler JL Question for the lifted rubicons with e torque engine IMG_1658
