Propane Fire Pits
jbcrane
40.5853° N, 105.0844° W
Just a Jeep, M'am.
3D Animation
I'm torn between one of these or the Howl R1 for our upcoming Dusy/Rubicon trip.
The Howl R1 is great. Got one about a month ago and love it. Bought the Ignik 10lb tank with growler and it's a solid set up. Any question just ask.
Jeep Wrangler JL Propane Fire Pits IMG_0844
SadRobot
SadRobot
Los Angeles
2025 Prius LE
Thanks for sharing. I just ordered the optional ‘Leg Locker’ that didn’t exist when I bought my Tripod Torch. Genius how the legs were designed to incorporate a new feature. Wonder if that was in their plans all along?
Yeah I feel like those should be included but I paid the extra $15 to get them. Without it the whole thing is super flimsy and you can't really move it around.
SadRobot
SadRobot
Los Angeles
2025 Prius LE
Ok did test #2 now with a full 5LB tank.
Also for those that haven't gone to the Tripod Torch website here's what it comes with:
Jeep Wrangler JL Propane Fire Pits IMG_0252
Jeep Wrangler JL Propane Fire Pits IMG_0253
Set up is pretty quick. I brought out the camp chair also to test out real world height.
Jeep Wrangler JL Propane Fire Pits IMG_0254
With the smaller tank it seems to want to stay at this level. If you turn it up more eventually the flames die down to this:
Jeep Wrangler JL Propane Fire Pits IMG_0256
Jeep Wrangler JL Propane Fire Pits IMG_0259
I had it going for about 45 minutes. A full tank should give me about 2.5 hours if I keep the flame this low. I guess I'll see how it does on the trip.
After seeing your moc-camp, I'm thinking my maximalist hi-back ARB chair or hydraulic rocker chair will clash with the minimalist itty bitty torch. The feng shui will be out of balance. Maybe if I put a 30 psi regulator on it to supercharge it?
On these things, they should provide a 2 stage regulator. The single stage regulators freeze up and the flow goes down to near zero. It was happening all the time on my home fire pit. I bought a cheap 2 stage regulator off Amazon and it cured it.
dragoneggs
Seabeck, WA
'22 Snazzberry Pearl JLR
SadRobot
SadRobot
Los Angeles
2025 Prius LE
Yeah the one they provide is 20 psi. The bigger tank seemed to have less issue keeping the flame higher. Overall even the smaller tank is better than the LavaBox. Not sure what was going on there but I tried 3 different regulators and after 8 minutes the flame was down to nothing.
I think the issue with those stage 2 regulators is that they require the regulator to be on the device (like on your firepit). On these smaller propane units you can only control it via a regulator on the hose.
SadRobot
SadRobot
Los Angeles
2025 Prius LE
And for those of you looking for a very light weight tank, I bought one of these composite 17lb tank a couple years ago and love it. Close to the capacity of a 20lb (5gal) steel tanks at about half the weight.
https://www.amazon.com/dp/B014V9H6R...fed_asin_title_3#averageCustomerReviewsAnchor
And I got a propane tank case that doubles as a camp stool. Top is padded for your tush.
https://www.amazon.com/Ignik-20-Pou...20-b5b4-bb524de0416f&pd_rd_i=B0C2JNWWWL&psc=1
I have the Ignik case for the 5lb. That 20lb one is nice I just don't have room to bring a 20lb tank with me. I miss all the space I had in the back of the 2dr.
dragoneggs
Seabeck, WA
Understand completely. The 5lb would probably work for me as well. I set up for week long trips which I haven’t been doing. Three days is usually max and I could always throw in a few disposable 1lb tanks. If I had to do it over, that might be the way I would go. One thing I do know, is with 20lbs I can cook and have a fire without any concern at all.
SadRobot
SadRobot
Los Angeles
2025 Prius LE
I originally bought the Ignik for my campstove. It works really well for that. If you want it to supply a large fire it's gonna burn through it real quick.
SadRobot
SadRobot
Los Angeles
2025 Prius LE
Quick update: I just had my tank re-filled for the trip and it only needed 0.2 gallons. So at that rate my tank should last me about 4 hours with the Tripod Torch.
dragoneggs
Seabeck, WA
Yeah if you don’t crank the flame too high, it seems to be pretty efficient. I like the vertical flame. I got my ‘Leg Locker’ today and loaded it in the Jeep. The Tripod Torch is so small it is on board all the time in one of my saddle bags.
Only-In-A-Jeep
North Georgia Mountains
2021 Jeep Wrangler Sport
The burn rate of propane is becoming more and more annoying to me. I have the Ignik original Firecan and the 5lb tank. It's ok for a single overnight but two nights is pushing it. Even one night is a challenge if you also want to fire it up in the morning chill.
I'm in a two door so space is premium.
If the tripod is significantly more efficient than the Firecan then that might be tempting.
SadRobot
SadRobot
Los Angeles
2025 Prius LE
That leg locker should definitely just be part of the kit. Do you carry propane mounted outside the Jeep also? For a bit I thought about getting a mount for my tiny propane tank and putting it on one side of my RSE spare tire rack but I ended up selling that also when I sold the Jeep. 🤷‍♀️
SadRobot
SadRobot
Los Angeles
2025 Prius LE
I'll be reporting back after the trip. I only need it to last 2 nights for about 2 hours/night. I'm not sure I'll even get that as weather report says thunderstorms at the park this entire week.
