Possible CB Antenna Mount
ResqFE
Ron
Ensenada Baja MX
2018 JL Unlimited
Genuine Mopar CHMSL Relocation Kit for JL/JLU
Part Number: 82215349
Can be had for $64+
Per Mopar: Use as a stand-alone component or with Oversized Spare Tire Carrier Modification Kit (P/N 82215355) & Tailgate Reinforcement System (P/N 82215356AB)
For the instructions in pdf form, click here:
https://www.allmoparparts.com/docs/82215349.pdf
Any thoughts on using this mount to install a Cb antenna instead of the brake light?
FatBoy01
NY
2014 Wrangler Sahara; 2001 Harley FatBoy; 2018 Wrangler Rubicon JL (Ordered)
Retired @ 55
Well, you could use the cutesy black grill affair itself for one or the other. No room for both antenna and light.
The black grill affair is very rigid, decent quality metal. It will remain rigid/strong even after your drill the needed antenna hole it it.
The black grill affair when installed resides far enough from the wheel so antenna would not be resting on the tire.
YES, I would say ok to mod for CB antenna... and would look/perform great!
Actually, I had thought some CB guy would really like this to use once he saw it.
Do shop around for price on the relocation kit. You should be able to get for a little over $75.
ResqFE
ResqFE
Ron
Ensenada Baja MX
2018 JL Unlimited
I'm actually hoping to use the existing hole, may need to shim it with washer.
dangerz
Roy
Fort Worth, TX
JLU Sport S
That's gonna sit pretty high up then. Good for the antenna, but not great if you ever wanna pull into a garage.
Fuel Fire Desire
Michigan
2018 JLU Sport S, 2020 JT Sport
Did it work?
By eyeballing it it looks like it doesn't come out far enough for the antenna mast to clear the rim offset and sidewall budge.
I almost wish I could find a pair of those extended lug nuts and make it myself. (And save $60)
W5MQS
Mitch
Temple, Texas
2018 Granite Wrangler Rubicon JLU; 2020 Mercedes GLB 250; 2013 Red Ford F-150 4x4
Interventional Cardiology
You can find antennas that fold over...at least you can for HAM radio. Comet makes antennas that fold over but I'm not sure if they do or not for 11m (CB).
W5MQS
Mitch
Temple, Texas
This is the link for Ham Radio Outlet... www.hamradio.com ...they have all sorts of whiz-bang gizmos for mounting antennas.
ResqFE
ResqFE
Ron
Ensenada Baja MX
2018 JL Unlimited
Did it work?
I looked online.... no luck on my end.
