ColonelSanders
- Mike
- Sep 3, 2023
- California
- 23 JLUR 4xe
You can disconnect the door plugs and drive to make sure it’s not a door ajar issue
This only happens during stop start?I purchased my 2024 Wrangler 2.0 in May and in October I started having a problem. It only did it 5 times between the last week of October and mid-December and then it started happening a whole lot more often. When I am at a stop with the auto/ stop steer feature activated, when I try to then go, it’ll come up “shift to Park to start “ and the D will flash on the shifter (so basically the same as if your car door is left open). And now the past two times it has done it, it also flashes “push brake and push button to start” and I can’t just shift into park and then drive but I have to turn the jeep back on. The dealership First said that it was a wire to one of my aftermarket lights run incorrectly on the battery and they moved the wire. That of course didn’t fix it. The second visit they said both batteries failed the test and my alternator was bad and they replaced those. The third visit was they said my grill insert and it was keeping the hood switch from contacting so they put a piece of foam in there. I picked it up today and it did it again tonight. I am at a complete loss and so frustrated. Does anyone have any insight?
This. The untold amount of grief that Jeep's implementation of Start/Stop on the JL/JT has brought to owners is beyond comprehension. It was there to improve test condition MPG by ~0.5MPG and enable Jeep to round up the CAFE MPG.This only happens during stop start?
OK. Stop using stop start.
