Overlanding battery
Lohkay
Montreal
JLUR
I hope someone can help me answer some questions in regards to adding an additional battery for my overland build.
I just finished a 2 week trial trip with most of my gear and with my 75l dometic fridge set on medium, I was going through the battery in around 15 hours which was fine as I was moving every day.
I would like to extend this time to 24 if not 48 hours so I wonder if I could add a second battery in the back, add an isolator up front and run wires to that second battery for charging.
I'm looking at a 200ah agm or lithium battery. Would that work? I have only rudimentary knowledge of car electric systems so I'm afraid I might forget something or do something wrong.
Thanx.
TrailTorque
JLU
Thanx.
Not to sure on this one but maybe @TTEChris can provide some guidance or know someone who can.
TTEChris
Houston, TX
www.tankcustoms.com
2021 JTD & 2021 4XE
Jeff1
CT
2019 JLUR
I'm not good with wiring electrical stuff so I went the portable power route. Picked up a Dometic PLB40 from REI a couple weeks ago. Not a cheap option but they had a 20% off coupon and I had a bunch of REI dividends and a couple gift cards so it was reasonable after all that. I haven't tested it in the vehicle yet but I should get 1-2 days or use with an ARB 37 fridge and it come with a car charger and wall charger. The other plus to it is that I can move it to other vehicles.
vavaroutsos
Pete
Scotts Valley, CA
2015 Sprinter Crew Van 2500 High Roof 144" WB OM651 Brilliant Silver, 2019 JLR 3.6L 6SPD Granite Crystal
There are a lot of options. A LiFePo4 battery will provide the best energy density and be the lightest, but charge management will be more complex. You will need four cells, a battery monitor, B to B charger, and contactor at a minimum. Or you can buy a pre-built LiFePo4 battery with protection and monitoring for quite a bit more money. A deep cycle AGM would be the simplest to setup with a charge control relay. Another option would be to replace your main battery with a dual purpose battery (starter & deep discharge), and add a solar panel and charge controller. I have two panels on top of my van (360 W total), and I have never had to plug in to shore power or charge from the alternator, but I am in NorCal.
Lohkay
Montreal
JLUR
Thank you for this thorough post. I had the intention to add solar panels eventually but I'm in Canada so the efficiency isn't there. I saw the pre-built LiFePo4 batteries and they are indeed pricey. I'll have to consider my options.
trav87
Travis
PNW
2018 JLU
I'm running a deep cycle RV battery hooked up off a isolator. I can go 2 days stationary this way, but I'm noticing that I'm not getting a full charge, and it seems to be the electronic controlled alternator. I just ordered a Redarc DC to DC charger that works better with newer alternators and has input for solar charging, and will be ditching the isolator.
RubenZ
Ruben
Deep South Texas
myjlproject.com
2021 Ford F-250, 18’ Toyota 4Runner
Theres a guy not he Facebook JL Wrangler Group who added batteries in the rear cubby. I'm trying to get more info from him but they charge as he drives and uses them for his fridge and ARB pump. Heres a pic of the setup. I think it would be cheaper than the Genesis unit.
vavaroutsos
Pete
Scotts Valley, CA
Looks like there is a charge control relay in there, something like this. This probably isn't the best solution with a smart alternator. Smart alternators won't generate sufficient charge voltage under normal conditions. Battery capacity is reserved and charge is dumped to the battery during braking under alternator control. This is done for fuel efficiency. To sufficiently charge a house battery a DC to DC converter needs to be used. Something like offered by Redarc or Sterling.
RubenZ
Ruben
Deep South Texas
myjlproject.com
Looks like there is a charge control relay in there, something like this. This probably isn't the best solution with a smart alternator. Smart alternators won't generate sufficient charge voltage under normal conditions. Battery capacity is reserved and charge is dumped to the battery during braking under alternator control. This is don't for fuel efficiency. To sufficiently charge a house battery a DC to DC converter needs to be used. Something like offered by Redarc or Sterling.
Wonder if instead of using the alternator one had solar panels on top roof rack? Then we'd be in business with a cost effective setup like that.
vavaroutsos
Pete
Scotts Valley, CA
You can do that, but then you need a solar charge controller (MPPT is best) which costs about the same as a DC to DC. Redarc does make a combo unit for about $100 more if you want both alternator and solar charging. Victron makes some nice solar chargers.
moodywizard
Lyle
2019 JLUR
I just posted a thread in the 3.6 section, I have the genesis daul battery kit and noticing inadequate charging as well given certain circumstances.. Wonder if there is a way to have the alternator charge at 14V constantly?
vavaroutsos
Pete
Scotts Valley, CA
The ECU controls the charging, so it's not likely an easy fix. Probably a question for @joe@zauto.
LincolnSixAlpha
Arizona
Not sure if this helps but genesis offroad makes a dual battery kit for the JL. I have never had the need for a dual battery setup, so don't know much beyond what I've seen on the market.
https://www.genesisoffroad.com/JeepJLDualBattery-p/185-jldbk.htm
For what it's worth, I installed the genesis dual battery system. Not terribly difficult to install, but a bit time-consuming. Their installation video is spot on. The best part is that it eliminates that little motorcycle battery under the fuse box. Quality components as well. I have an ARB fridge and recently returned from a trip to the Canadian Rockies. I'm mobile during the day, but have gone 16+ hours running on the batteries, and have no fear now about running the batteries down since the second will disconnect the two batteries at a certain level (12.4, or 12.7 v, cannot remember).
If I had to speculate, you could easily get 36 hours or more out of this setup. I'm just not still enough to test beyond the 16 hours I was not mobile.
LincolnSixAlpha
Arizona
What's the bead on this? I noticed that the JL was constantly sitting at 14+ volts attempting to charge these two batteries. However, since returning from my very long trip to the Rockies and about (5K + miles) this seems to be no longer the case, as the voltage settles down within an hour or two.
