Oil separator purpose?
58Willys
Geoff
Western Washington
2018 JL Sport
This thing is a mystery. I have a factory service manual that describes “description and operation” for most components; but nothing on this. I have a 3.6, so I can’t look at it to figure this out. Only thing I can guess is it’s part of the return flow to the crankcase, to keep frothy oil from the pickup; which can cause dry sumping and/or cavitation, causing loss of oiling.
Wes1980
wes
N GA
2019 Rubicon 2dr
separated oil drops down into the oil pan if the crankcase itself has air moving around. The draining oil relies on simple weight. Because the oil separator is bolted directly to the side of the engine block, the oil accumulates on the baffle plates until it forms heavy droplets. Gravity pulls this heavy liquid downward through a dedicated drain passage that sits safely below the active windage and turbulent airflow of the upper crankcase
TrailMax
Max
Arkansas
2023 Wrangler High Altitude 4xe
Well apparently a team of engineers thought this 2.0L Turbo engine needed an oil separator thingy, and apparently they did a pathetic job engineering the oil separator thingy, and apparently it's top secret why it's there.
After a handful of people in recent threads have pointed out how much the oil separators are leaking oil, in vehicles that aren't that old or with that high of mileage, I'm starting to think an oil separator delete is the best remedy. Maybe it's not that simple?
Is it possible the oil separator is part of the PCV setup? Can an oil catch can be mounted in place of it?
I don't think an oil separator delete would be a good idea, especially on the 2.0 Turbo since it is a GDI (gasoline direct injection). With a GDI, you don't have a fuel mixture going through past the intake valves to clean carbon build up and gunk - meaning you're going to have to go in there and clean your valves, walnut blast them, etc.
Catiajockey
Jon
Melbourne FL
2018 JL Rubicon unlimited
so far with my 18 with 121K miles it has served to cost me about $2600. replaced at 60K for 1400 and just last week at 121k for $1200.
Tim_JLU
Tim
2019 JLU Sahara
Yeah I don't understand why they are prone to leaking.
I am lucky 82k on my 2019 and only a seepage for the last few years.
croppz
Zach
North Carolina
2021 JLU Rubicon 2.0T
Plastic part mounted to an aluminum block and many heat cycles
It’s stupid, it should have been aluminum, probably wouldn’t happen if it was honestly.
