OEM LED headlights
Mickgolf00
Perry GA
Jeep Wrangler JL
are the OEM units sealed? or can you replace the LED bulbs?
There is a YouTube video out there that shows someone replacing the guts of the assembly with a multi-color light. I wouldn’t have the nerve to do it.
Mickgolf00
Perry GA
Jeep Wrangler JL
Okay, but it's not just a bulb that you cN swap out, it's like "headlight surgery"
I literally lol’d. You are correct. Not an easy bulb swap. Surgery is a good description of what they were doing. Great reply!
steffen707
Wisconsin
2020 Gladiator Sport S (Gladys) - 89' Civic SI
THANKS! I was wondering if perhaps you can just swap out the low-beam led bulb for an HID bulb with ballast and not have this "not enough heat to melt the snow buildup problem".
guess i'll just deal with it.
JLEEPER
JEFF
NEW YORK
www.headlighthaven.com
2019 SAHARA, 2003 EVOLUTION, KX125
lighting specialist
We have completed the first set of adapters that will successfully convert your halogens to Mopar LED. Plug- and - Play. No Tazer or re-flashing from the dealer is required. Simply plug in our adapters to correct your flickering, turning off, and high beam/low beam not working properly. we will include our fuse-taps as well so you can connect easily to your fuse box or you can tap into the parking lights so you control when the halos are on or off.
contact us for more details
Jeep Wrangler JL OEM LED headlights JL HL ADAPTER2
Jeep Wrangler JL OEM LED headlights JL HL ADAPTER3
Jeep Wrangler JL OEM LED headlights JL HL ADAPTER4
Looks great! Do you have a link to your site?
JLEEPER
JEFF
NEW YORK
lighting specialist
Hello the site is www.headlighthaven.com. Currently the site is 'under construction' but is functional. These adapters are not yet posted, but if you are interested, just message us, I can get you more details.
Thank you,
Atticus1634
Suburban New York
2018 Sahara JLU
Thank you,
To both JLeeper and EgGreg and anyone else who can assist:
I have a 2018 Sahara JLU with the halogen package.
I am upgrading all of the exterior lights to LED.
I've already successfully switched the taillights to the LED Hourglass lights.
I took the easy route and installed LED bulbs in the stock Fog Lights, no problems.
This is where it gets interesting and I want the info and necessary hardware before doing the swaps for the Morimoto Fender DRL/Indicator and Mopar LED Headlights.
I received the Morimotos last week and the Mopar LED headlights from Tuscon Mopar yesterday.
I simply unplugged the stock H13? cable from the existing headlight bucket to test out whether the headlights/halos work. Unfortunately, but as expected the Halos do not work. The low beams and high beams did, however.
Here's my question: In the educated opinion of everyone here who has successfully completed what I'm trying to do:
A. Should I install the Morimotos in the fender first since I am going to have to tap into the DRL wiring in order for the Halos to work?
B. What hardware (modules) do I need in order to get the headlights and morimotos working?
*The morimotos are the latest edition, do they have the resistors pre-wired to prevent hyper flash and insure that the sequential blinkers work?
*Would the EgGreg or JLeeper module added between the bucket and factory cable be necessary?
BTW, first post here, I apologize for the wall of words but I want to get it right!
Thanks all,
myoldmetal
Blake
Lake Stevens, WA
18 JLU Sahara, 14 Mustang GT, 17 Super Duty
Construction Management
I bought a set of JW Speaker LEDs from Amazon and ordered the Morimoto 7" headlight retrofit kit, as well as a set of LED fog from The Retrofit Source. Very happy with the lighting and didnt have to touch any wiring or take mine to the dealer for programming
JLEEPER
JEFF
NEW YORK
lighting specialist
The factory computer doesn't like when we switch to OEM Mopar LED. Many times there are other issues when swapping the halogen headlights to LED. As mentioned in these posts, usually the high and low beams do not work correctly ( the low beam shuts off when you turn of high beams) and after a little while the headlights shut off. Our adapter harness will fix these issues and your halos can be wired easily.
The whole conversion should only take 2-3 hours for everything. You can do everything in a day. I would swap the headlights and leave the halo wire in the 'area' make sure the headlights work properly then move onto the turn signals. We are authorized dealers for Morimoto and The Retrofit Source as well and can beat most prices.
Also the bulb on factory halogen is H13, but the factory connector into the bucket is not an H13 on the JL.
Kraty1
Batavia IL
2018 Jeep Wrangler Unlimited JL
Sales & Marketing
Yesterday was one of the days I’m happy to have the non-LED halogen bulbs. Weather in Chicagoland was crazy and a few errands ended up leaving a frozen mess. Saw another LED JLU and could barely make out his headlights as I passed him, but the standard halogens gave off enough heat to melt the mess.
dcdanny
dcdanny
Daniel
CA
2014 wrangler sport. 2018 Rubicon
Anyone know if @EgGreg is still selling the adapter? I can't find it on his Ebay account. Thanks....
lepcat
j
texas
2019 Sting Grey JLUR, Sky One Touch
I’ll list by special request. Sent pm
Are these adapters still needed? I have a 2018 JL sport. Just installed the rubicon 3 piece metal bumper with led and some oem takeoff led's. I am going to order the Tazer.
nev-fgt
Rich
Fairfield County CT
2007 Jeep JK, and 2018 Jeep Jl
The tazer will take care of any issues with flickering and high/low, did mine last night. I installed OEM LED fogs and headlights. Still need to connect the halo wire though. Tazer also lets you set it so the fogs stay on with the high beams which is pretty cool. Also put in the diode dynamic switchbacks which the tazer fixes the hyperflash so no need for a resistor.
