OBD Jscan Settings
Renrens91
Ren
California, SoCal
2018 4D Jeep Wrangler Rubicon JL
Hi People!
What other handy and useful adjustable settings on the OBD Jscan. So far I’ve calibrated my tire size and set my max load inflation pressure TPMS setting to 25. I was considering disabling my SDAR Travel Link so I no longer get the weather warning but I'm not sure if that will also disable travel related info such as closest or cheapest gas near me feature because I use it frequently when I'm on a road trip.
What did you guys change on your JL/U?
Cheers!
Ormond Beach, Florida
Retired at 55 ..
@Renrens91
Here is a JSCAN setting that will light up those dark dark back roads..
Fogs with High Beams:
ADAPTATION
---> Vehicle user settings --> Front Fog Lamp Dropout Enable On/Off --> Target Value = Deactivated
This is a cool one that will make your JL stand out from the others on the road..
Turn Signals for DRL's:
Maybe need: ADAPTATION ---> DRL--> Day time running lights Configuration- Canada DRL
ADAPTATION
---> DRL - Day time running lights - settings --> DRL Lamp Location --> Turn Signal DRL
Retired at 55 ..
@Renrens91 will not want this one based on his post.... but to me though, it was my absolute pleasure to get rid of the constant Weather Alerts.
I do lots of interstate road trips and use another, far far better alternatives to get " closest or cheapest gas near me"
For those that want to say goodbye to Weather Alerts:
Disable Weather Alerts:
ADAPTATION ---> Radio user settings --> SDAR Travel Link
Feature Present On/Off--> Target Value = Deactivated
TrentYoung
Trent
Phoenix
2024 Jeep Wrangler Rubicon X 4Xe
@Renrens91
ADAPTATION
ADAPTATION
That.... is the exact and only reason I bought the JScan. To be able to run my high beams at the same time I run my fog lights / driving lights. I added on the Baja Designs "Squadron" in place of the MOPAR LED fog light which throw out a combined 7,000 lumens, then the headlight (high beams) which throw out about another 4,000 lumens.... all combined will light up the desert night sky.
Bryce
Bryce
Acworth, GA
2019 JLUR
I tried the Auto High Beam settings, but it doesn't work on my '19 with ACC. It shows up on the radio menu, but the setting gets checked and then immediately unchecks itself.
TPMS and fogs with high-beams are the 2 that I've actually used.
