Not Starting
mwilk012
Oklahoma
2018 Ocean Blue JLU Rubicon
Service
First thing I would do is check for any obvious modifications or damage to the wiring under the instrument panel. Often this is where a dealer will install a remote cutoff or tracking device. A lot of times these are left unmonitored after the loan period and may fail.
Barring that, check during the no start event itself. With or without scan tool data available? Do you lose communication during the test? Pick a most likely point in the circuit based on the actual circumstances you’re seeing, and check for signal. If you’re only not getting signal to the starter, it’s a pretty quick check. You just need to set up the right rest points prior to cranking attempts which can suck without two people.
Terrymo
Terry
2023 JLURXR 3.6 ET
@mwilk012 does this for a living so my question is only for my own curiosity. Are there any diagnostic trouble codes present?
Also what does “won’t start period“ mean?
Doesn‘t crank at all? No voltage to the starter relay etc?
Hgrace
Hgrace
Harry
Southern California
19 JUL Sport S, Fleetwood 33 Terra SE. Lincoln MKC
Thanks. I've been troubleshooting various electrical systems for decades.
It's definitely in the ess or anti theft system.
No dealer or other work.
