NO START WTF 4xe 2023
BigMaCro
Moved to Iowa from Alaska
www.youtube.com
2021 JLU 4xe Rubicon
Carhauler
If your not certified to work on high voltage automotive electronics, I'd recommend you just take it to the dealer. You know Life>Money
He's talking about the 12v battery.
IanNubbit
Ian
NJ
2022 JT 6MT Sport & 2023 JL 2 Door 6MT Sport
Jeep Dealer Tech
Well seeing as the issue was a rubbed through wire, I'd argue my point still stands. With these PHEV's, even when you disconnect the 12V battery, the 12V system is not powered down. The 400V system still is able to supply power to the 12V system.
GATORB8
CLT NC
21 JLURe, 06 LJ, 25 HDZR2
Well seeing as the issue was a rubbed through wire, I'd argue my point still stands. With these PHEV's, even when you disconnect the 12V battery, the 12V system is not powered down. The 480V system still is able to supply power to the 12V system.
It’s a DC-DC charger, the voltage at the 12V is still around 12V.
PatriotX
Midwest/Great Lakes
2022 4xe
My literature says 400 volts. Your dealership have different info?
alphawolff
california
2021 JLU
It has a 400v and a 12v system. The 12v system runs all the traditional vehicle electronics. And to respond you whom you're quoting, no, with the 12v system powered down the 400v system will not function. The 12v's one and only job is to latch the contactors for the HV battery. If it doesn't have the ~10.6v or so required to do that the vehicle will not function or start. If you disconnected the 12v battery while the vehicle was already running it would, however, continue to run.
