Spring lift or spacer lift ?Currently running a 2.5” Rough Country lift. Want to replace the shocks with something that will give a better ride. All suggestions are welcome.
Different shocks probably won’t help. Usually companies that offer shocks and springs pair/ tune them with each other. Without knowing the spring rate, it will be hard to pair different shocks. Tires play a huge role in ride quality. 30-32 psi on C or D rated tires is best.Spring/Shock lift
Yeah, you should at least do extensions, or a little longer shock. It’s best to stay in the middle of the stroke as possible for the best performance.What do people think about new shocks paired with stocks springs on spacer lift? I am planning on putting on a 1.5inch spacer and have read that without extensions, even a modest lift like this can put undue stress on the OEM shocks.
Yeah, you should at least do extensions, or a little longer shock. “It’s best to stay in the middle of the stroke as possible for the best performance.”
