Ratbert
PNW
2022 AEV JL370 JLURD
Software Engineer
Hell, most all new engines that I know of have wiring harness that could be installed properly with your eyes closed because the connectors only fit specific sensors etc.
Hopefully you think that's a good idea.
Or maybe you think they should document the entire thing in a manual and force you to go line by line.
No, they learned to make it foolproof. And that's "a good thing".
Guv
2018 Wrangler Sport 2.0 E-Torque 2 Door
Why would you think otherwise?
Interesting…
link3721
Tom
North Carolina
2023 JLU Rubicon 4xe High Velocity
The engineers did everything except the one simple thing that should have been done: a different thread pitch for each plug.
Those look like different thread pitches to me. Also, you could only remove and replace the main chamber before removing/replacing the pre-chamber plugs to avoid inadvertently mixing them up.
WXman
Central Kentucky
"Complex Tech" equals less reliability, longevity, and future serviceability.
Long live the Pentastar V6! I've got 300k flawless miles combined on P-star engines since 2012 and I love my new '25 too.
jeepingib
Dusty
College Station, TX
18' JLUR Punk'n
BBQ prophet
Jeep Wrangler JL New Jeep 2.0T Hurricane 4 has complex tech [Engineering Explained] 1774271129374-86
Are we looking at two different pictures? Those are the exact same size and pitch of threads. And it's a matter of when, not if, for even a dealer technician to put 8 pre-chamber plugs in an engine.
Guv
I could see it being a 12mm, good call, especially when you see the size of the pre-chamber.
If this is a doctored photo the sonofabitch that did it was successful in stirring up a lot of shite.
Guv
Because you're defending Jeep's "opposite of foolproof" approach when it comes to sparkplugs.
So you can’t wrap your brain around the fact that maybe, possibly the application might require a totally different spark plug!
You do know or maybe you don’t that the AF ratio in a pre-chamber is richer than the main chamber. Heat range, reach or size and composition of the electrodes is probably different.
Do you think that they would sacrifice performance so people like you could get out there with your crescent wrench and hammer and F it up at home?
jeepingib
Dusty
College Station, TX
18' JLUR Punk'n
BBQ prophet
Sounds like the perfect reason to actually use a different size and thread for the plug then, doesn't it? Yet, they didn't. Which is why we are calling it out as stupid.
Guv
Do you have the plug in front of you so you can definitely make sure of the difference?
Does anyone?
Ratbert
PNW
Software Engineer
No, it's not doctored.
Does anyone?
Here's the video from MOPAR:
At least they tried to give clues about what goes where, but it's definitely possible to trash the engine when in a hurry.
Starting with personal attacks now?
Interesting...
Guv
Feature Specification
Type Iridium or Platinum
Gap Size 0.023 - 0.027 inches
Heat Range 7
Resistance 5000 Ohms
Thread Diameter 12 mm
Insulator Height 51 mm
Pre chamber plug is 12mm
link3721
Tom
North Carolina
The one on the right looks like a slightly shorter pitch between threads to me. Either way there are procedures that can be used to mitigate the chance of error.
  • Like
Reactions: Guv
Dusty Dude
Colorado Springs, CO
Heat Range 7
All of these specs mean nothing if the plugs can be swapped by a “Primitive Pete” mechanic.
