New 2 door rubicon needs advice
Maverick909
I.E.
The new bfg 37’s weigh almost exactly what the 35’s do and the 37’s now come in a C. Wouldn’t it be the same thing to run those new 37’s bfg ko2’s then?
unless you plan to run 8-10 or higher IMO on a two door. 2" lift and 35's would be a sweet spot. I currently have a 2.5" lift and patagonia MT 35's and i dont hit that much on my belly skids.. you could go the route of getting 35's and a set of full skid plates for the belly and that should take most your worry away and later on put a lift on. two doors are so much more nimble than a 4 door y'all can miss some of the hard stuff LOL.
ChadTx
Chad
Central Texas
Looking to order 2021 Wrangler Rubicon 2 door
I suggest you get the 35x11.5R17 Toyo AT3's and run them on stock wheels with no lift. This will give stockish ride and handling. I am running Nitto's version of that tire which is more of a mud terrain and thus noisier. I couldn't be happier with this tire on a trail/touring Jeep but I'd want something more street oriented for a daily driver. Note that I found 30 psi to be right for the street, so you'll need to get a Tazer or have the dealer change your recommended inflation pressure.
You will be amazed at where you can go with this tire. Rather than a lift, I elected to install a full set of skid plates from Mountain Off Road Enterprises and a set of LoD rocker guards.
The toyo at3 with no lift is how I’m am leaning. U think it would ride and have the pep very similar to stock with the at3?
davewald
Bellingham, Washington
www.davewaldrop.com
Sort of, kinda retired....mostly
I recently upgraded my Rubi to the BFG 315 35's load range C and I'm glad didn't go to 37's. I don't get to 8th gear nearly as much as I did on the stock BFG 285 33's, which makes me think I would need to re-gear for 37's. Mopar 2" lift is going on this week if UPS can get their act together.
Kreepin1
Kirk
Central Illinois
1982 CJ7, 2006 TJ, 2012 JKR, 2021 JLR
Yes. Especially with the automatic. Even with a manual transmission mine drives great.
Mikester86
2022 JLR
Did you calibrate the speedometer for the new tire size? If so, you should still see 8th gear quite frequently.
blnewt
New Mexico
Just ask @cosine he knows!
Keep in mind you have a Rubicon w/ the 1.5" wider axles, 4:10 gears, and higher fenders. There's been a bunch of Rubicons around here that are running the wider 12.5" 35s without issues. I think there's a large thread around here w/ that exact setup.
Ridgway Jeeper
Frank
Ridgway, CO
2021 JLR
Real Estate Agent
Ours does everything fine on the stock 33's. I will fit 35's once the tires I want become available again. They will go on the factory wheels with the factory suspension. 99.9% of people do not need to lift a Rubicon and run 37's. Looks cool but really not necessary from a functional standpoint. I agree with the comments about needing to re-gear for 37's and even then the 3.6 will struggle some with them.
Kreepin1
Kirk
Central Illinois
Agreed.
Keep in mind not everyone lives at 7,000 ft. Here in the flatlands a 3.6 could handle 37's even without regearing.
ChadTx
Chad
Central Texas
Thank u. That definitely gives me some insight. Will u please post a picture of before the lift on the 315’s and after the lift? That would really help out
ChadTx
Chad
Central Texas
If u find that thread let me know. Searched for it and can’t seem to locate it
ChadTx
Chad
Central Texas
What tire are u wanting?
calemasters
Allen
Springfield, Mo.
2026 Moab 392 w/27X package & Escalade
Retired Mechanical Engineer
Ordered a 2 door rubicon in the middle of July. I ended up going with the 3.6 with etourque. I also went with the automatic. So here’s the dilemma I’m dealing with. I’m either going to leave it stock height and go to a 35 like the toyo at3 or I’m considering doing the mopar lift and getting the new bfg 37’s that came out that are c. They weight just under 65 lbs. I know the bfg runs small. This Jeep will be my daily and I want to take trips in it and retain all factory warranty. Do u think the bfg 37’s in c will be to much for the 3.6 and I’ll loose all pep? Should I just stick with stock ride height and go with the 35’s? What are ur thoughts?
I would not go larger than 35s. The 35s fit perfect on my JLUR, even the spare. If you go with 37s with will need many other modifications, plus you will have more unsprung mass, and you will seldom see 8th gear.
blnewt
New Mexico
davewald
www.davewaldrop.com
My profile pic is the 35's with no lift. I really like the look, but I do some moderate to difficult off-roading and planning to do the Rubicon, Moab, etc. I'm pretty sure they will rub on some of the harder obstacles. Plus, I have already gouged/scratched pretty much every skid plate that I have installed, so the extra 2-3" will help me save money on spray paint.
