Need jeep steering expert
Twnca007
Travis
Hesperia, Ca
2019 jeep wrangler rubicon unlimited
2019 jeep wrangler jlu. 2” mopar lift. 315/70/17 mastercraft mxt’s(new tires just got installed with alignment). Drove straight as an arrow steering wheel perfect center with old tires. I am attaching my alignment report …all looks great I think? Right from get go steering wheel clocked left 20 degrees and hard right pull. Very reputable place installed. They worked it and finally said it was a bad (new) tire. Any thoughts and help very appreciated.
Jeep Wrangler JL Need jeep steering expert IMG_8220
jadmt
jeff
montana
One of my My local tire dealers that carries mastercraft told they talked people out of mxt tires due to pulling. Said if people insisted they still tried talking them out of getting them
Twnca007
Twnca007
Travis
Hesperia, Ca
Interesting…..glad they have a 30 day return policy :) they went ahead and just ordered 4 more new tires …install again this Friday. Keeps doing it they get to keep their tires I’ll go with something else! …
thank you
Twnca007
Twnca007
Travis
Hesperia, Ca
Wish I didn’t now ….. it was threw in with the purchase of tires
Willys41
Larry
Pleasanton Ca.
2020 Jeep Willys
I have see time and time again tires pulling left or right.
To find out if it is the tires swap the front tires,
If it now pulls the other way you know its the tires.
dstevens
CA
2024 JLURX
I agree as well - swap front tires side to side.
The only thing that was changed in the alignment was front toe. If the steering wheel is off center, then they did not adjust the drag link. You can do that yourself - it is very easy. Drive the vehicle straight in a flat area and come to a stop. Loosen the sleeve on the drag link and turn it until the steering wheel is now in the center. Tighten sleeve pinch bolts.
Willys41
Larry
Pleasanton Ca.
2020 Jeep Willys
Yes the drag link may need adjusting put until you correct a possible tire issue you may be holing the steering wheel to left or right compensate for a bad tire.
Twnca007
Twnca007
Travis
Hesperia, Ca
All thank you ….and yes I’m definitely holding the steering wheel to the left to compensate the right pull
jadmt
jeff
montana
for the record the alignment numbers look good. It should have one finger steering....
Deleted User 38384
Why'd you get an alignment, especially if it drove straight as an arrow. Changing tires doesn't change your alignment.
Yes I'm with this guy. I recently got an alignment because I thought it was a good idea, turned out I just threw away $150 instead. Didn't need the alignment... lesson learned I guess. I think the biggest help for me with it pulling a little bit to the right in my case, is my upgrade to 37-in tires, I need to install my steering stabilizer soon!
Ratbert
PNW
2022 AEV JL370 JLURD
Software Engineer
It's pulling to the right after the alignment?
