Need help putting on step bars!!!!
yadd3ie
Yadi
Jamaica, N.Y.
Jeep Wrangler Sahara Unlimited 2017
I just traded in my 2017 Sahara for a 2023 rubicon I need help putting on new step bars. I don’t have the tools and I’m not car handy
The Chubbernaut
Modesto, CA
2021 Jeep Wrangler Willys
Substance Abuse Counselor
What bars do you have? Do they bolt to the body or the frame? Did it come with mounting brackets and hardware? Tools tend to be fairly cheap if you're not worried about reusability. In fact, your Jeep should've come with a ratcheting wrench, so all you'd probably have to invest in is the right size socket...which you may also already have.
The best way to gain confidence and competence is through experience and failure. I would recommend finding an instructional video on youtube (if you know the brand, most manufacturers seem to post installation videos). If that isn't something you wish to do, I'm sure any shop would be willing to charge you for the pleasure!
Sparty
SW Michigan
04 TJ, 21 JTR, 21 JLR
Sounds like it's time to buy some tools and learn to become handy
Sazabi19
'20 Gator Gladiator Sport S, '22 Gobi JLR
Not being a dick but YT is really gonna be your friend. All you'll really need probably is a socket set, torque wrench (to be proper), and maybe a MAP torch depending which bolts you're taking off. If you're taking off body bolts GL, you may wanna have a shop do it because it takes rounds of heating the bolts to loosen the locktite (you'll want gloves cuz the heat transfers to your wrench) and make sure you're applying upward pressure, shearing a body bolt requires a trip to a shop so they can extract it (somethings tells me you don't have a welder). Simple bolt on parts like this are really beginner level add-ons, you'll be surprised how easy it is, just takes time and minimal knowledge, mostly common sense.
roaniecowpony
Retired Engineer
Many manufacturers have videos on installations. Virtually all have instructions, either paper or online. These instructions often have a list of tools required.
If you are intending to learn to use tools, I'd recommend you buy decent tools from the start. For my choice, I often choose Tekton tools. Nice balance of high quality and economy. Undoubtedly, there'll be many brands others favor.
And last, some have lists of dealers on their website, which may install their products.
dchemphill1
Nebraska
2020 Wrangler Rubicon Recon
School Administrator
The most difficult part is holding the part while also putting the bolt in. Get a buddy, girlfriend or wife to help hold weight while you put bolts in. Advice: don’t have your girlfriend and wife work together. It will add a certain difficulty that doesn’t help the process.
roaniecowpony
Retired Engineer
If the steps you buy require the removal of the body mount bolts, I'd highly recommend you find a very experienced shop to install them. While it is possible to remove the bolts without heating them, it can be a disaster as well. Heating with a torch is also not great. The best and most successful method involves an expensive induction bolt heater.
Solary Induction Heater Bolt Removal, 1100W 110V Magnetic Induction Heater Kit for Rusty Screw Removing, Nut Buster Tool with 3 Coil - Amazon.com
Joe's_Roxy
Arkansas
2018 JL Rubicon, 2009 JK Sport, 2006 LJ Sport
Quality Manager
Seriously???!!! I used my cheapo Harbor Freight Heat Gun to remove mine after the highly experienced and qualified dealership body shop said they couldn't be removed.
https://www.harborfreight.com/power...t-11-amp-dual-temperature-heat-gun-56434.html
Applied heat for several minutes and tried the bolt. If it didn't move, heated some more. Rinse, lather, repeat until I was able to remove the bolts and installed my ACE Rock Rails.
Sazabi19
But hearing the pops as you're loosening them build character...
Did mine with the MAP torch I bought just for it. It was a bit nerve wracking as the torque I had to apply was greater than what spec called for, but I got them off, just had to go slow and methodical. A lot of shops around me refuse to do body bolts as well.
Joe's_Roxy
Arkansas
Quality Manager
Yeah, was definitely nerve wracking since I had already broke the first body bolt that the dealership replaced for me. That is when they told me that the body bolts were not supposed to come out. This forum and youtube were my friend in finding out how to remove the bolts. And...with the luck I had already been having on my damn near brand new Jeep...there was NO WAY I was putting any flames near my JEEP!!!! HAHAHA
Terrymo
Terry
2023 JLURXR 3.6 ET
I successfully removed the body bolts. Everybody loves to brag about how easy it was like they cheated death. I know I felt like I probably had some luck on my side. OP admits they own no tools and aren’t handy so there’s that.
roaniecowpony
Retired Engineer
Somes are easy and somes are a buggar. Mine were a buggar. I used a MAP torch. But a bolt induction heater will heat the bolt itself, with less heat on other parts (rubber mounts) and make it ready to remove in seconds.
If you encounter one that's a buggar, it could ruin your day.
SlickRicksWilly
Rick
2024 JLW (ordered)
What type of steps do you have? Knowing that will help point you in the correct direction. How they mount plays a big part of the install as you can see by the body mount bolt breaking concerns. The $170 induction bolt heater seems a bit overkill, especially for someone who said they don't have tools to begin with.
