My wheel is leaking something?
Jeep Junkie
Jeep Junkie
Muhammad
Seattle, WA
2024 JL Wrangler Willys
Is this seam thingy or the location that warranty doesn't cover?
Jeep Wrangler JL My wheel is leaking something? 20251020_122156
Jeep Wrangler JL My wheel is leaking something? 20251020_122146
Jeep Wrangler JL My wheel is leaking something? 20251020_122140
Jeep Wrangler JL My wheel is leaking something? 20251020_122617
Jeep Wrangler JL My wheel is leaking something? 20251020_122634
jeepingib
Dusty
College Station, TX
18' JLUR Punk'n
BBQ prophet
Yeah, that's from something external, not a part defect. Does suck, but don't put it off long. Once all the grease has been slung out, and water can get in, it will damage things. How quickly that happens is up for anyone to guess. But consider that this joint spins with every rotation of the tire.
Jeep Junkie
Jeep Junkie
Muhammad
Seattle, WA
Roger, will fix it ASAP. But even a 1000 miles is enough to damage things? I need to drive, its my only vehicle ☹
jeepingib
Dusty
College Station, TX
18' JLUR Punk'n
BBQ prophet
The grease lubricates the bearings, it doesn't take too long with no grease for metal on metal wear and spalling to begin. You can try to put fresh clean grease back in the hole, and seal it up. But results may vary. Usually just end up a mess.
Jeep Junkie
Jeep Junkie
Muhammad
Seattle, WA
Roger, will put some grease there until the fix 🤩👍
jeepingib
Dusty
College Station, TX
18' JLUR Punk'n
BBQ prophet
Just remember that it's going to keep flinging it out until the hole is sealed, or the boot is replaced. Centrifugal force and all that jazz.
Jeep Junkie
Jeep Junkie
Muhammad
Seattle, WA
Hey, is this a job that Firestone could do?
jeepingib
Dusty
College Station, TX
18' JLUR Punk'n
BBQ prophet
Not sure. I know they do some general maintenance, and I believe they would do it for IFS, but not sure if they would do the boot on a Jeep solid axle. It requires removing the wheel bearing first, then pulling the axle out, and repairing it before putting it back together. Give them a call and see what they say.
Jeep Junkie
Jeep Junkie
Muhammad
Seattle, WA
Will do. Their rates are lower that's why I asked. Will report!
Left Field
Tim
Western WA
'67 RS-SS Camaro, 2021 JLUR392
To me, that looks more like something stabbed it, like a branch or something. Others can chime in here though.
Ditto.
Jeep Junkie
Jeep Junkie
Muhammad
Seattle, WA
Hey, if I do a lot of research and ask here, can I do it myself? I will go to the self serve garage and the owner walks around in the shop if someone needs help.
Jeep Junkie
Jeep Junkie
Muhammad
Seattle, WA
They said they don't do boot only, they will do the whole axle ☹ But I asked them for an estimate, lets see how bad it looks.
jeepingib
Dusty
College Station, TX
18' JLUR Punk'n
BBQ prophet
I'm not sure what your mechanical skill level is. Generally speaking the steps are, remove tire and wheel assembly, remove brake caliper (do lot let caliper hang by brake hose), remove brake disc, remove ABS sensor from wheel bearing, remove wheel bearing. Remove axle shaft assembly, Remove old boot, install new boot (clamps can be tricky), Reinstall in reverse order. Getting the axle shaft assembly back in the splines properly can be a pain. Especially on the disconnect side.
jeepingib
Dusty
College Station, TX
18' JLUR Punk'n
BBQ prophet
Whole axle is going to be expensive.
