My A/C Keeps Exploding
puppykhan
Luigi
NYC
Wrangler 4xe
While driving my 2024 Willis 4xe, I hear what sounds like a small explosion, see a puff of white smoke come out of the engine area, then the A/C no longer works.
I had this repaired. A hose burst, and lost all the Freon. Freon is expensive to replace, like a thousand or two.
Then it happened again a few months later.
The repair is supposed to have its own warranty but still.
Anybody else having trouble with their A/C like this?
Dyolfknip74
Ottawa, Ontario, Canada
2021 JLU Rubicon
I am pretty sure there hasnt been others, at least not posted on here.
They dont use Freon anymore but yes, the refrigerant is spendy.
Freon is now used to spray on baby seals and punch them through the atmosphere in the Artic, or it was banned in the 90s due to ozone layer decline. I cant remember which. ;)
DaltonGang
Doesn't Play Well With Others
Never heard of that issue. Just let the warranty do its thing. For the future, when you run low on Freon(refrigerant), I still call it freon, the 1234xyz? can be replaced with the older, cheaper, and just as good 134a Freon. You just need a $15 adaptor to charge it.
Gregj
Greg
West Texas
2018 JLU Rubicon, 2018 JLU Sport, 2023 JTRD, 2017 JKRR, 1998 XJ
I hope they look for an obstruction in the expansion valve. Something is driving the high side pressure up and that can destroy the compressor.
Gregj
alphawolff
california
2021 JLU
expansion valve is a common fault on these but i've seen failed compressors a lot too. it's one or the other i'd say
