mopar lift question
AC77
AC Abegian
Los Angeles
Autobody , singer-songwriter
Hello, anyone who has installed their Mopar lift kit, did you also replace the rear track bar ?
GATORB8
CLT NC
21 JLURe, 06 LJ, 25 HDZR2
The Mopar kit doesn’t come with either track bars.
Roky
Roky
I always install a relocation bracket for the rear.
AC77
AC77
AC Abegian
Los Angeles
Roky
Roky
thanks , and what brand ? or does Mopar offer one?
Mopar doesn’t make one, I use RK mostly…. But they all will work, some require drilling….Do you have the Mopar kit on your rig already?
AC77
AC77
AC Abegian
Los Angeles
i ordered it a few days ago, should arrive in a week or so, why ?
i do have the JKS front track bar installed last year, when i did the level kit ... made some difference back then
Roky
Roky
Read this…… it’s what I do when installing the Mopar kit… Don’t know if it’s any better since they switched shocks, but I stopped installing them for people unless they brought me the extra parts listed in here……customers were getting over 3” and would come back to have me fix it, so now no extra parts, I don’t install it, lol….
https://www.jlwranglerforums.com/forum/posts/1454124/
AC77
AC77
AC Abegian
Los Angeles
GATORB8
CLT NC
thanks for this , im going to buy the JKS as i want to keep it the same as the front, which is around $180
For ~$30, I'd grab the isolators @Roky recommends in his link and throw them in when you install. Cheap insurance against having to pull the springs again.
AC77
AC77
AC Abegian
Los Angeles
RK isolators ?
ym0bc1
San Francisco Bay Area
JLUR
RK isolators ?
I got the one from MetalCloak. Any high quality rubber would be sufficient.
The mopar isolator is garbage. The spring has been bowing since day 1, and mopar's youtube video saying it's an engineered feature. I don't buy it and it turned out to be caused by garbage isolator.
AC77
AC77
AC Abegian
Los Angeles
Wowowee
Bern
Canada
Jeep Wrangler Sahara
I’ve put the Mopar lift kit, come with lower control arm to correct caster.. on my 21 Sahara, it looks like got more that 3”of lift.
Also replaced the track bar (adjustable)front n rear, offset was noticeable.
You’ll need an alignment, re- center steering wheel
