Mopar Lift, adjustable track bar?
Ponce
Eastern NC
2018 Rubicon JLU
Retired USMC. Currently USMC pilot instructor
I am finally getting around to putting a lift on my 2018 JLU Rubicon. I just added 35's and now plan on adding the Mopar 2" lift. My question is should I order a adjustable track bar with the lift or wait to see if I need it? If I do with that lift will I need bracket extensions? I am open to adjustable track bar specific recommendations. Will there be a need for an adjustable rear bar?
betsy
jeffrey
maine ,usa
2019 jl rubicon 2dr ,2016 jk rubicon hard rock 2dr
When I install a jeep lift adjustable track bars front and rear are always installed, also make sure that the sway bar links are the correct length, I usually toss the ones included in the kit and replace them with JKS adjustable links. I am also in the process of installing a Mopar Lift in my JLR, I have also included some MetalCloak adjustable control arms, upper bumps & a steering stabilizer relocation kit (raises the steering stabilizer above the tie rod. I have been lifting jeeps for 25 years and that is what works for me.
Ponce
Ponce
Eastern NC
2018 Rubicon JLU
I am starting to get paralysis by analysis. I am also looking at the Rock Krawler "flex no limits" 2.5 lift. It includes an adjustable track bar. So the price would be almost a wash.
Any input on that kit?
I do basic off roading no extreme rock crawling.
Dyolfknip74
Ottawa, Ontario, Canada
2021 JLU Rubicon
You'll be fine with Mopar. Lift it and give it a go. If the axles being off center bug you, it's easy to add track bars.
The RK kit is also amazing and a more "complete" lift.
It's really up to you and availability.
Roky
Roky
RK is not just for rock crawling, in fact it’s on road ride is one of the best. It’s actually one of the best kept secrets……..people that run RK….know……..? ……… as for the Mopar lift, the amount of lift you get will/ should determine if you need to square it up and stretch it out……….best of luck to you……
https://www.jlwranglerforums.com/forum/posts/1454124/
Cuyose
Shawn
Piedmont, SD
2020 Jeep Wrangler Rubicon
Data Analyst
This^^^^ I installed Mopar lift myself and after adjusting drag link to center steering. It drove and tracked like a dream. I already had a Yeti adj track bar on order due to comments here, but honestly didn't need it. Its cool I have it, its way beefier than the stock and "red", but honestly you really dont "need" it.
GATORB8
CLT NC
21 JLURe, 06 LJ, 25 HDZR2
No one here is qualified to argue with @Roky , but you won’t be able to run stock wheels FYI.
word302
Oregon
JLU
The RK lift is heads and shoulders above the Mopar lift. Get the RK and don’t look back.
Roky
Roky
Stock not stick. Argh!!!
The RK control arms are bent up for ground clearance instead of inward like the stock lcas. So you need a wheel with 4.5” of back space or less so it won’t rub the control arm when turning to lock….. stock wheels are 5 ish backspace. You can run spacers with stock wheels, or adjust out the turn stops ….
