UKJeep2018
- Luke
- Oct 2, 2018
- United Kingdom
- Jeep JL Wrangler Sahara
Hi,Dude read my post one more time. The response you got is not true, YOU DONT NEED TO BUY A NEW SET OF LIGHTS OR BREAK OPEN THE HEADLIGHT FOR THAT MATTER.
All you need to do is add the missing 4th pin to the existing plug you have and wire it to the BCM and have your dealer activate the code for you simple as that.
Im from Saudi and have already done that so dont listen to the local agent/dealer BS
Can you please clarify what you did to get it to work?
So all you did was add a 4th pin to the connector?
So I assume the halo female pin in already there or did you have to do anything else to get it to work?
If that’s the case then all I have to do is import the USA wire harness?
. They even insist on putting 5.7 L of oil in the new engines even though the manual says 5 L only
