Mopar LED headlight upgrade
4573davidb
Caine
Georgia
2021 Jeep Gladiator Mojave
I upgraded my halogens to mopar LED headlights and used a Tazer to switch settings
I changed both the “HALO” and “HEADLIGHT LED” to YES.
Can someone confirm to put my brain at ease?
Xorak
TN
2020 Hellayella Sport, 2023 Reign Sahara
That is correct and worked for me on my 2021.
Xorak
TN
If your headlight harness has 4 wires at the plug, you can just enable with the Tazer. If you only have 3 wires, you'll need to manually run the 4th wire for the halos to work.
4573davidb
Caine
Georgia
Thank you very much. I have a 21 and it does have the fourth. All is good ?
stealth1178
md
2021 jl wrangler2dr sport
so i have a question i have a 2022 wrangler sport s 2 door which came with factory led headlights and fog lights i went to the dealership today and asked about upgrading my taillamps to mopar led lamps they said it is vin specific and it is 1800 dollars for both yet when i checked mopar it showed 375.00 for each taillamp is this correct?
Punkn89
Alex
Maryland
2019 Wrangler
just buy the LED tail lights and change them yourself, super easy.
Crowbar
usa
20 JLR, 23 JLUR XR
So you now know that dealer will stick it to you. I'd find another dealer. And do the tail lights yourself. So simple.
