Modified Rusty's Tire Carrier
Gdub
Geoff
Tucson az
2018 JL Sahara
Engineer
So I took va72mlibu advice and cut mine. Thank you for all the help.
VA72mlibu
VA72mlibu
Eric
Alexandria, VA
2019 Mojito! JLR; 1972 Chevy Malibu; DHC-7 & BeechCraft King-Air (operated, not owned)
Nice man! Looks great! How did you cut it off?
Gdub
Geoff
Tucson az
2018 JL Sahara
Engineer
basically the same way as you recommended. Taped it off, used a 4” cutoff wheel and then ground it smooth and touched it up with semi-gloss black. Matches perfectly and cannot even tell it was done.
VA72mlibu
VA72mlibu
Eric
Alexandria, VA
StingJLUR
Fairfield, CT
2018 Jeep Wrangler Unlimited Rubicon - Sting Gray
I am considering this tire carrier and I am also interested in cutting off the extra tab. What paint did you use to match? Great job guys!
itsmike
Socal
Wrangler
Is there a good way to add a Cb antenna mount once the left side of the tire carrier is cut off?
Hayseed_JLUR
Midwest
2019 JLUR, 2015 JKU
I used a Cooltech mount upsidedown. I had to enlarge the holes slightly and mounted where the highlift jack bolts mount. Works perfect and have a 1.2 reading on 1 and 40.
VA72mlibu
VA72mlibu
Eric
Alexandria, VA
I spayed a little self-etching primer, then two coats of semi-gloss rattle can (Rustoleum probably?) I masked very carefully, so I was only painting the newly exposed metal. It's nearly impossible to tell mine was cut.
Ingrum
Andrew
Dallas
www.jlwranglerforums.com
2019 Wrangler Unlimited Sport; 2018 Jaguar F Pace
I had to remove by 35 spare today and was surprised how heavy it was. Leads me to believe that I need this product with this modification. Do they every go on sale?
anviljl
Andrew
JLUR
Like it never even happened!
Jeep Wrangler JL Modified Rusty's Tire Carrier too-easy-gif-6
I’m about to cut my tab off. Did you use a 4” metal cutting wheel on a grinder to cut it off? And has everything still been rock solid?
Gdub
Geoff
Tucson az
2018 JL Sahara
Engineer
yes and yes. Worked like a charm. Tape it off.
VA72mlibu
VA72mlibu
Eric
Alexandria, VA
Jeep Wrangler JL Modified Rusty's Tire Carrier 3B663FD9-D0F0-45C5-84EC-D78C2489FF18
Well, I did it. I even left the carrier hinges bolted to my Jeep. It was super easy. Thanks for the advice!
Jeep Wrangler JL Modified Rusty's Tire Carrier borat
