MOAB Edition JL Club Thread
tatarin
Russ
Bloomingdale, IL
2019 MOAB Mojito Sky One-Touch, 2015 Lexus RX350F-sport, 2005 Camry SE
:flag:
tatarin
Russ
Bloomingdale, IL
Bump
DrPerez007
Wisconsin
See Signature
Public Safety & Legal Consultant
Well, it’s been awhile, but my Mojito paint finally arrived (only been waiting about two months). And with that my project to mount the Warn PIK (Power Interrupt Kit) for the VR EVO 10 winch is now complete.
So I bought an angle bracket, cut it to 13” and then painted it (yes, I realize it probably now needs a second coat). To avoid a “dissimilar metal issue,” I bought a strip of rubber ‘door sweep’ and cut and mounted it below my bracket. This keeps my metal bracket from directly touching the Jeep body (I’m probably a little over protective). Then I mounted the Warn PIK to my bracket. Look closely and note that the Warn PIK comes with its own mounting isolators so it keeps the metal of the PIK off the bracket and, thus, out of contact with the Jeep body. Prevents certain adverse reactions with the operation of the solenoid. [Make sure no part of the solenoid touches anything on the Jeep.]
Then four attachments to the solenoid:
1) main power (positive) cable from the winch;
2) power for the solenoid (to my controller box, with individual fuses and relays, which is that black box mounted to the right of the solenoid; this is only to operate the solenoid, which, in turn, will “turn on and off” the winch);
3) ground for the solenoid to the battery (winch ground is separate); and
4) power cable lead to the vehicle battery (positive).
Then in my interior cabin, I have a six-position switch box with (small) cable that runs out thru the firewall to that black control box mounted on my bracket and operates the solenoid (along with various lights and such). When I push the winch button (#4 here marked ‘AUX‘ b/c they didn’t have a ‘WINCH’ sticker), I can hear the solenoid click and the winch is then operable. Rumor on the Forum here is that this particular winch has a small power draw at all times (probably on the parasitic level), so the use of the Warn PIK should shut that down, as well.
Winches make me nervous because most of them are wired “HOT” to the battery without fuses. If you ever slice a winch power cable or perhaps have an accident, without a fuse to cut power you could have a real problem (can we say “Fire!”). The PIK should prevent that by supplying power to the winch only when it is specifically turned on. I plan to run a few power draw tests later to confirm the power draw on all components.
Everything needed was included in the Warn PIK box and I thought it was nicely packaged. I did not use their switch because I routed it thru my controller. If you have the factory AUX switches (I don’t) I believe you can use one of those instead of the Warn switch if you so choose.
That’s it. A few pics. BTW, that strut you see to the left is the Red Line Tuning hood lift (which installs in minutes and really works well; goodbye prop rod!).
Have a great day!
Jeep Wrangler JL MOAB Edition JL Club Thread 1F487346-8586-43F1-9710-C53710846AED
Jeep Wrangler JL MOAB Edition JL Club Thread CCC5ACC8-C6A2-4C6F-8465-001365641596
Jeep Wrangler JL MOAB Edition JL Club Thread 2DC6D764-D39F-49E0-9C80-7824FF90D662
Jeep Wrangler JL MOAB Edition JL Club Thread 1F653A32-4F4C-4FDA-8755-E9E3960040CD
Jeep Wrangler JL MOAB Edition JL Club Thread 6B174EB1-4B99-44EE-B09C-E5AC4ED47F6B
Jeep Wrangler JL MOAB Edition JL Club Thread BF5CADE5-1FA1-4135-9863-C2C52788C1B6
Jeep Wrangler JL MOAB Edition JL Club Thread D2E773D2-D615-4E7F-AE96-410DC330A33B
tatarin
Russ
Bloomingdale, IL
Lived up to the “Mall Rated” status:CWL:
tehfrr
WA
2023 Jeep Wrangler Rubicon 4XE 20th
2019 Moab; photo taken on the way home from the dealership about 1 month ago.
Figured I'd go out and buy the off road mods I need but I'd probably never upgrade the luxury items.
Previous owner had a 3" body lift and 35" mud tires installed.
Since then, I got rid of the mud tires and added snow rated all terrain tires.
On my floor waiting for install - 12k lb winch and reinforced bull bar
Next up - proper suspension lift (3.5-4")
Currently in the shop for leaking rear axle seals on both sides.
Jeep Wrangler JL MOAB Edition JL Club Thread 2020.1117.8374
tatarin
Russ
Bloomingdale, IL
Finally got around installing the Oracle integrated reverse lights.
99wishes
2018 Jl Moab
I have this on my list to do next. Originally I was going to buy the Rigid lights and drill holes. The more I look at the Oracle lights the more I like them. What did you connect the lights to? Auxiliary or reverse lights?
tatarin
Russ
Bloomingdale, IL
I tapped to the reverse lights.
