Missing Odometer and clutch message
Heimkehr
Pennsylvania
2021 JLU 2.0T
is that something I can replace or is that a complicated process
The CANBUS pieces behind the glovebox door slide/click into place very easily. They're inexpensively sourced online; I purchased two spares on eBay. Unplug the connectors from the originals and plug them into the new ones. Done.
Maverick909
I.E.
Most members have done it them selves. There is quite a few threads on the canbus connector failures
The Fixer
North Jersey
2018 Mojito! JLS, 2018 Firecracker JLUSS
Teacher
I think it's very common with this cluster, at least on the 2018's. My wife's JL has been doing this on and off for the last couple of years with the same Push Clutch even though it's an auto and random 999999 or no mileage showing. It seemed to happen more frequently as the batteries aged for us; we changed the OEM batteries out in the summer of 2021 so these new ones are getting close to 4 years old. Initially after we changed the batteries the weird cluster behavior basically stopped, and has slowly resurfaced over the last year so that it's basically every other drive cycle has some oddball thing going on in the cluster (transfer case and rear diff showing Locked even though it's in 2WD and it's a Sport, along with the mileage glitches and such).
FWIW my son's 2020 JLUR has been normal, knock on wood. He bought it CPO 18 months ago and he's put about 20K on it.
WranglerMan
WranglerMan
Will
Greenfield Indiana
2018 Wrangler JLU Sahara
my batteries were just replaced 3 months ago and on my most recent test before taking this trip they tested fine using my Motopower tester, I have not gotten the 99999 mile error it just disappears randomly and the clutch msg appears all other things work normally
MitsJeep
South Carolina
2018 Black JLUS
Jeep Wrangler JL Missing Odometer and clutch message IMG_0783
Jeep Wrangler JL Missing Odometer and clutch message IMG_0784
WranglerMan
WranglerMan
Will
Greenfield Indiana
Well I got back from my out of state travel and proceeded to first use JSCAN to check for any fault codes and there were none so then I reset all ECU’s and then removed the SGW bypass module and start/stop elimanator and put all back to factory original.
I did a few restarts and all seemed normal but then the odometer disappeared again and the clutch message showed up but those are the only two intermittent messages I received so I may go to the local dealer and see what the cost is to have the cluster reflashed but if its really pricey i may just let it go as it works 99% of the time.
Dale's Jeep
Dale
Michigan
2018 Jeep JL 4door Rubicon
Retired U.S. Army 23 years
I would not ignore it, but it is your ride. This is a couple takes of mine. I have an auto and it displayed clutch.
I get the same exact thing as you are getting to.
WranglerMan
WranglerMan
Will
Greenfield Indiana
I don't get the 999999 odometer reading it just disappears along with the clutch message being displayed but all other parts like trip miles, mpg’s etc… show normal and if I shut if off and go back and start after the EVIC powers off the total miles on the odometer come back and says press brake to start but 99% of the time it works as designed.
I'm sure doing the TSB is not free and I have 91k miles on my 2018 but I will go in and get as estimate on the reflash when I have time.
MitsJeep
South Carolina
2018 Black JLUS
I’ll see if I can dig out the paperwork when I had it done to see the cost. It’s probably in my file. It “may” have been a part of the diag fee. But things may have changed by now or I could not be remembering correctly.
Jeep Wick
Wick
America
2022 High Tide XR
Mechanic
Has anyone tried disconnecting the battery again to see if that fixes it?
Valpo Jeep
Doug
Valparaiso IN
From time to time my mileage does not display or it will show 999999 miles for a short bit. Even had it tell me the outside temp was 800F. Even have had the clutch message in my auto
Don’t feel like paying an hour of shop time to reflash
WranglerMan
WranglerMan
Will
Greenfield Indiana
I’m sure it will be over $100 minimum to have it flashed
MitsJeep
South Carolina
2018 Black JLUS
Found my service order. $191.28 for the reflash. It annoyed me enough to get it completed. I had just purchased it, and I like to keep my vehicles tip top.
WranglerMan
WranglerMan
Will
Greenfield Indiana
I'm sure its gone up some since you had yours done so when I have time I will go in and give them the TSB number and see what they give me for an approx cost.
WranglerMan
WranglerMan
Will
Greenfield Indiana
I will try this today as I have exhausted all other options other than going to the Dealer which I truly hate doing
