Missing Odometer and clutch message
WranglerMan
WranglerMan
Will
Greenfield Indiana
2018 Wrangler JLU Sahara
Well just a quick FYI…
I disconnected the batteries ( both negatives ) for approx 30 mins and reconnected and still randomly not showing total odometer miles and still randomly displaying press clutch message to start so will have to go to the local dealer here when my schedule allows to tell the the TSB number to see if they can address
Spank
You ever get this figured out?
I'm testing the SBM theory on mine by leaving it disconnected. It's only been a few days, but all the glitches have disappeared. I was under the mistaken impression you had to leave it plugged in to retain any changes you make on the computer, but apparently that isn't the case.
Major CANBUS problems is what ultimately points to the star connector or something more nuanced, causing the loss of major systems, wipers turning on despite being off, the dash lighting up like a Christmas tree, and the Jeep spitting out dozens of codes. I don't have this. My issues are limited to settings and configuration of the EVIC itself. Display items such as the Clutch to Start, the odometer vanishing, corner items changing or disappearing, and the menus being all screwed up when I go to correct them are all I've experienced.
Jeep Wrangler JL Missing Odometer and clutch message PXL_20220213_172730236
If I can remain glitch-free for at least an entire week, I'm pretty confident the SBM is my issue.
Dale's Jeep
Dale
Michigan
2018 Jeep JL 4door Rubicon
Retired U.S. Army 23 years
Got mine reflashed and knock on wood no more issue's. 75 bucks was the total cost for mine. 2018 JLUR.
Dale's Jeep
Dale
Michigan
Mine did the same thing for a long time plus all the other glitches went to dealership for patch or whatever it's called and so far so good
Spank
Did you have to jump through any hoops or do a diagnostic to get it done or did you just ask for the flash?
WranglerMan
WranglerMan
Will
Greenfield Indiana
No my issues still exist but I have yet to visit the dealer, its pretty random on the total miles disappearing and clutch message andI also noticed that total trip miles sometimes freaks out but that's it as far a glitches.
Dale's Jeep
Dale
Michigan
Just went to dealership made appointment 30 mins and done.
WranglerMan
WranglerMan
Will
Greenfield Indiana
What is the SBM you disconnected are you talking about
Spank
The Security Bypass Module that comes with a FlashCal or Tazer to allow changing values in the computer. I don't know if it's the culprit or is even something that actually screws up the EVIC to begin with. I'm just going through a process of elimination at this point and others have speculated it possibly being the issue.
If the glitches appear again, I'll do the EVIC flash that @Dale's Jeep mentioned.
WranglerMan
WranglerMan
Will
Greenfield Indiana
I removed the bypass module I use with JSCAN along with the stop/start eliminator and it had the same malfunction maybe your the lucky one
