Missing Aux Switch wire
N0GX
Kyle
Iowa
2020 JLU Rubicon
I was wiring up some lights to the Aux switch wiring under the hood. I noticed I only have 4 wires under there, I have the wires for aux 1, 2, and 4, and the battery power wire. I appear to be missing the wire for Aux 3, and the keyed power wire. This is on a 2020 JLU Rubicon. Is this normal?
Terrymo
Terry
2023 JLURXR 3.6 ET
Unless I’m remembering incorrectly you have Aux 1-4 wires under the hood. In the interior you have those same 4 wires plus battery positive and ignition positive for a total of 6. How are you determining the under hood wire is battery positive rather than an Aux switch wire. Check out this @Northridge4x4 video.
Jeep Wrangler JL Missing Aux Switch wire IMG_1637
kah.mun.rah
Merenkahre Jr.
Duat
4 under the hood and 6 on the interior:
(posted by @Brazilbombsqd):
Aux Switch 1 F93 - 40 Amp Beige/Pink Interior (passenger side under instrument panel) & Underhood (right side near battery)
Aux Switch 2 F92 - 40 Amp Green/Pink Interior (passenger side under instrument panel) & Underhood (right side near battery)
Aux Switch 3 F103 - 15 Amp Orange/Pink Interior (passenger side under instrument panel) & Underhood (right side near battery)
Aux Switch 4 F108 - 15 Amp Dark Blue/Pink Interior (passenger side under instrument panel) & Underhood (right side near battery)
Battery F72 - 10 Amp Red/White Interior (passenger side under instrument panel)
Ignition F50 - 10 Amp Pink/Orange Interior (passenger side under instrument panel)
Also see other AUX switch discussions @ https://www.jlwranglerforums.com/fo...switches-configuration-installation-diy.1477/
N0GX
Kyle
Iowa
2020 JLU Rubicon
I will have to double check, I could have sworn I read that there were 6 under the hood as well, and that the one that was hot matched the color code of the battery wire in a pic I saw. Maybe switch 3 was on when I tested with my test light.
Terrymo
Terry
2023 JLURXR 3.6 ET
I just checked mine. 4 under the hood, 6 under passenger side dash. @kah.mun.rah gave you the best info
NULL POINTER
Carmine
Free state of Florida, NW of JAX
2024 Gladiator Rubicon X, '19 VetteZ06 7spdVert,4
Old Fart
FYI, if the aux switches were not factory installed, and instead installed via the add-on MOPAR aux switch kit, then you get 4 under the hood, and only 4 in the passenger footwell. The kit looks just like the factory install inside, and works the same way with the vehicle setup in the dash screen. The add-on MOPAR aux switch kit does not have the battery wire or ignition wire in the passenger footwell. It also has its own set of 4 fuses under the hood.
kah.mun.rah
Merenkahre Jr.
Duat
I can see why putting a battery wire next to the battery is a little redundant but it would be nice if they included the ignition wire under the hood. Sadly the 4 aux wires are all that you will probably find under the hood.
Ratbert
PNW
2022 AEV JL370 JLURD
Software Engineer
Not really redundant since that wire is fused.
Opus
Midwest US
Nope. When I wired up my ditch lights there were only 4 wires under the hood as ka.mun.rah lists.
