Midland MXT275 install
BDinTX
Dallas, Tx
Hopefully the moderators are ok with this post. If not you can take it down and email me 20 lashes with a wet noodle.
I installed an MXT275 under the passenger seat of my 4 door. The ghost antenna is mounted on the passenger side of the roll bar on a DIY bracket you could make with precut steel from the hardware store. All the wiring is hidden beneath the factory trim.
Things you'll need:
Trim removal tool
T25, T40, & T50 Torx bits
10mm socket
Ratchet and extensions
3/8" coarse thread (3/8"-16NC) tap
Terrymo
Terry
2023 JLURXR 3.6 ET
Enjoyed the details, the fact that you call out what tools you used, and the dry wit.
Ct_Formula
Orange Ct
2021 Rubicon JL, 2011 JK Sahara
Self Employed
Fantastic Video, great job on it. I'm so glad I waited to install mine. Love the antenna mount.
Blue Bear
Matthew
Seattle
2023 Hydro Blue JLUR
Air & Space Museum Curator
Great video, but I have to disagree on one part - the background colour of the handset should be the light blue. ;)
BDinTX
BDinTX
Dallas, Tx
I'll be honest, I was surprised to learn you could change it at all.
chrisswank
Michigan
2016 JKU Rubicon, 2024 392 on order
Great job on the video! Thanks for taking the time to document the process.
rcadden
Ricky
Asheville, NC
Marketing
Great video man.
I wasn't going to do an onboard radio, because I like the freedom of handhelds, but the battery life on mine is getting shorter, so I'm starting to research.
A few questions:
1. Where did you mount your handheld?
2. Does the rear rollbar mount work with the hard top installed (albeit slightly blocked)? Moreso than the cowl mount?
I like the passenger seat mount, but the antenna and handset are what's giving me headaches.
BDinTX
BDinTX
Dallas, Tx
Hey thanks!
I thought I would be done with the handhelds once I put it in but no. I still carry them with us for when I get out to spot.
I put in a two arm 67 designs phone holder. They collaborate with Jeep Uniq for radio holders. I got one that holds the walkie AND the handset so they’re both right there at arms reach.
https://jeepuniq.com/collections/67-designs-compatible-mounts
You’re being kind calling what I made a “mount” :) It’s just a piece of metal with a bend in it. It works fine on my SOT and on my wife’s hard top. It did NOT work with the Bestop fastback. So I made a different one for hers that clears the top.
Sparty
SW Michigan
04 TJ, 21 JTR, 21 JLR
Things you'll need:
Trim removal tool
10mm socket
GREAT video - thank you. This is exactly what I want to do. How has the performance of the antenna been?
BDinTX
BDinTX
Dallas, Tx
Hey thanks! I have identical installs in both jeeps and have tested out to about 1/2 mile with no noticeable degradation in audio quality. Sorry I can’t give anything more specific though. Most of the time we are within eyesight of whoever we’re talking to so I haven’t felt the need to improve it.
