GATORB8
While the Ranchos 9000s are adjustable, IIRC they are Twin Tubes and a step back technology wise from the Monotube Fabtech Stealth's you posted before.I'm talking to representative from Northridge, and the ones he's suggesting has the following:
Fabtech Rancho 9000xl 2-3.5in lift
Front: Front:
Extended Length – 27.09 Extended Length – 25.21in
Collasped Length – 16.85 Collasped Length – 18.16in
Stroke Length – 10.23 Stroke Length – 7.05
Rear: Rear:
Extended Length – 29.69 Extended Length – 28.59in
Collasped Length – 18.38 Collasped Length – 19.89in
Stroke Length – 11.32 Stroke Length – 8.7
What do you think about those numbers? Looks like I'll lose a lot of travel length, but honestly not sure what that really means.
Edit: my formatting did not stick. The first numbers are Fabtech, and the second are Rancho.
Twin Tubes will generally have shorter travel from the same package length. In this case you would lose ~2" of front downtravel (droop) and a little over an inch out back.
EDIT: Note, depending on the amount of installed bump extension, you may be able to use the longer 3.5-4.5 Rancho 9000s and at least eliminate the loss in travel.
