The Great Grape Ape
- Mar 30, 2017
- Canadian Rockies
- 2015 JKU AspenX 5spd , 2015 JK Sport 6spd
Something I've been wondering about is whether there are door removal steps that you could cheat on if you had manual windows.
Just to follow-up on this a bit, you can leave the door stops unhooked and then will stay recessed into the door frame. A feature Manley showed off in L.A.Yes as there is no electrical connector to unfasten. The JK nuts are the same way and it appears the JL will be the same. Now the new door stops will they need to be unscrewed,,,
As much as I like the fact that there are no wire looms for the manual doors/locks in my JK, the new easier to disconnect system for the JL, might make the hassle almost trivial now, as it’s as easy as a flip of a switch not a slide of a toggle and trying to get the finicky little clip to disengage, I have high hopes the new system will be much easier & quicker.
