DexterJeeper
It really depends on your situation. I would say it makes sense to regear if you have lifted your Jeep, upgraded your tires to 35" or more, added a lot of weight or need to tow. I did all of the above so re-gearing was very necessary and hence the reason for 5.13. And yes, you can definitely feel it off the line.Yeah that sounds right. Restarting the jeep fixes it every time.... so other than it not fixing the low voltage issue, would you recommend re-gearing? Was there a noticeable difference in any other regard?
If you're just running bigger tires (<40") and a lift, I would say regearing to 4.88 should be enough. But remember, the trade off to any regearing is potentially worse gas mileage and higher revs on the highway. For that, you'll get better pick up and the ability to use all 8 of your gears again. The best thing to do is to talk with a transmission shop about how your Jeep is setup and what you plan to do with it, the reputable ones will give you good advice.
