Lost several systems at once
Jukebox
Virginia
2021 jeep wrangler jlu
Hoping someone can help me before I have to take to the dealer. Wife started our 21 JLU last week and dash reads “fuel sensor unavailable”, “TPMS unavailable”, “service 4WD”, “start/stop unavailable”, and the “check engine”. Jeep starts and runs fine. Thinking it would have to be a module or bus for all these system to stop communicating at once. Anyone have any ideas???
Edit: was able to pull code P0463 with an obd2- Fuel Level Sensor “A” Circuit High.
Jeep Wrangler JL Lost several systems at once DF805CB8-FFCD-40AB-B390-914FB5CEDCFD
Jeep Wrangler JL Lost several systems at once CE18D510-853A-45C4-A498-EC18CEE7E5F9
Jeep Wrangler JL Lost several systems at once 2F400208-FFDA-4C96-A64A-0A5CA50FC5FE
Alan W
Alan
2023 Wrangler High Altitude
what were you able to find out?
did you just restart and it went away?
Jukebox
Virginia
Nothing yet still showing the same. Hoping someone on here can help me get to the bottom of it.
Ten North Prez
Sweet Valley, PA
2023 JLUR, Toyota 4th Gen V8 4 Runner
Jeep Wrangler JL Lost several systems at once 1674571412578
Ten North Prez
Sweet Valley, PA
I really don't have a clue but I'd be looking at the Aux Battery right out of the gate. I have seen a great deal of random sensor failures and trouble codes produced by these poor quality batteries throughout this forum and others. Likely wouldn't hurt to go to the fuse panel and give each one a push to make sure they are seated properly as well.
Hope you find the issue quickly.
Jukebox
Virginia
Aux batt was my first thought. Voltage is good on it. Check all fuses for connection and made sure all relays are making. Thanking maybe a CAN buss issue, but not sure if any of them would affect communications of all these systems
Ten North Prez
Sweet Valley, PA
You weren’t playing with a Tazer or the like, right?
Jukebox
Virginia
No, the only thing I had done was hook up some lights to the factory aux switch about a month ago.
Cuyose
Shawn
Piedmont, SD
2020 Jeep Wrangler Rubicon
Data Analyst
Maybe goes without saying, but remove your main battery leads for about a half hour, then go and reinstall, making sure they are good and snug and fire it back up. A dodgy ground connection can make the computer do all sorts of stuff.
Jukebox
Virginia
Yeah that was my first thought. Disconnected for about an hour. Posts are clean and connections snug.
Dyolfknip74
Ottawa, Ontario, Canada
2021 JLU Rubicon
How did you check aux voltage?
entropy
Foothills of the San Gabriels
OF top 1% content creator
Did you also check the main battery?. I had similar issues a couple years ago and everyone was telling me to check the Aux. Well, my aux was fine. but the main was out, it wouldn't hold charge.
Sometimes battery issues can be really hard to detect with these JLs because the dual battery system can mask issues. It did so with my Jeep. You have to disconnect the aux negative cable from the main negative post. Read voltages for both batteries and if you can, load test them. Then let it sit like that overnight and the next day, read the voltages again. They're connected in parallel and will keep each other charged if left connected.
You don't need to mess with the fender liner to check the aux voltage.
