Long Term Success/Damage from Hoists?
JLURVA
Shawn
Sterling, VA
2019 Wrangler JLUR
Has anyone had any long term storage or repetitive use issues (ex. hard top cracking / deformity) with hard top hoists and the points of contact on the hard top? I'm currently looking at a harken hoist and have noticed other owners using pool noodles to modify padding. My main concern is that the hoist seems to "support" the weight of the hard top in places that are not normally meant to support load.
HealthRebel
Jerry
Colleyville, TX
2020 JLRU Ocean Blue
My hoist consists of 4 ratchet straps. The left front strap hooks to the left rear strap on the inside of the top. The right front strap hooks to the right rear strap. There are 12.5" pool noodles in each of the 4 corners where the straps make contact with the top. In my opinion, this distributes the weight more evenly and in a safer manner than having each strap hook just to the corners.
This works very well. Very easy to lift off and put back on.
There are lots of YouTube videos out there. Just do your research.
ziff73
Houston, TX
2020 JLUR & 2013 BMW M5 (former)
You mind measuring the width at the bottom? I plan on building a shelf. Thanks.
JCJR824
Michigan
2020 Wrangler JLUR Billet Silver
I built a shelf for mine to avoid any possible issues from that.
I like this setup. I have 12' ceilings in my garage so I may build a hoist and cable system with a shelf like you did.
What are the dimensions of your platform?
BrntWS6
Land of the FOID
2019 JLUS, 2002 WS6
I made a video on my setup, specifically detailing a metal "T" brace for the hardtop. Can't remember the dimensions of the platform but i say them toward the end.
ziff73
Houston, TX
Thanks. you said 48" x 69". Careful putting the eyebolts in at 90 degrees to the load. I've read the support is materially reduced at such an angle.
aprez27
Andrew
Long Island NY
2018 JL Wrangler Rubicon
10 years of hanging my JKU's top from my garage with no issues, 5 years with the TJ same story.
