wibornz
- Ted
- Aug 3, 2018
- lansing, Mi.
- Website
- www.instagram.com
- JL Unlimited Rubicon
- Occupation
- Retired from Corrections....I have stories.
The real question here is how many times is @JeepCares going to apologize because Jeep has not been able to address the failing sensor? There are people on this board that have had three and four axles swapped into their $50,000+ Jeeps and the problem is still not solved after three years.
A guy on the internet figured out how to stop the sensor from leaking diff fluid into it and ruining it. A company has figured out how to bypass this junk sensor, and yet with all the engineering marvel at Jeep and Dana, they can't figure this out. What a shame. What a shame. The sensor takes about 15 minutes to swap out and many people have their Jeep sitting at the dealership for weeks waiting for a whole to axle to be installed.
The amount of time I have in calling Jeep, Chrysler and Dana, I could have easily installed over 100 new sensors. This should be the simplest fix in the world. Your sensor fails, the Jeep dealership replaces it under warranty and keeps replacing it under warranty until Jeep and Dana figure out how to manufacture a sensor that does not leak diff fluid into it and then fail. Hell you can change out the sensor almost as fast as one can do an oil change.
I bought a whole new rear Dana 44 Axle to get the sensor. That sensor failed in approximately 2000 miles. Jeep thinks it okay that I just keep buying axles to get the sensor.
This is how easy it is to replace the sensor. Just remember that as you drive your Jeep for a month or two waiting on a new axle and then it is in the dealership for a week getting the axle replaced, that it really is a 15 minute job.
