Locker Position Sensor Potting - DANA 44
croppz
Zach
North Carolina
2021 JLU Rubicon 2.0T
croppz
Zach
North Carolina
WannFly
Priyo
Atlanta
2021 Rubicon 4Xe, 2026 MOAB
Cyber security
Does anyone know if the new models (25-26) have the same flaw with the sensors? While i am still waiting for my 26 MOAB 392, if the sensors have the same problem, thats the first thing I wanna do
Jmos4
2020 Challenger Scat Pack M6/2007 Ram 2500 G56
Hi,
Believe there was a post about the newer axles using a different designed sensor.
Regards,
WannFly
Priyo
Atlanta
Cyber security
Hi,
Regards,
I remember seeing something about that too, but cant find it anymore. Glad I wasnt imagining things (again)
Terrymo
Terry
2023 JLURXR 3.6 ET
Per @THAW
I'm not sure whether the new sensor is potted. I doubt many people have seen the inside because it's a more robust design - molded into one piece of plastic, instead of the older design with two different plastics attached with glue.
No, the new senor is incompatible with the old axle
Jeep Wrangler JL Locker Position Sensor Potting - DANA 44 IMG_0695
WannFly
Priyo
Atlanta
Cyber security
Thanks @Terrymo Much appreciated. Now the question is... should I drill into it or not. If its one-piece molded design, may be we dont need to pot?
Terrymo
Terry
2023 JLURXR 3.6 ET
I don’t have the answer. Have there been reports of failures of the new style on the forum? Or maybe @mwilk012 or @alphawolff can answer.
ym0bc1
San Francisco Bay Area
JLUR
Not really. Even for the old design.
The PCB inside the sensor is just for filter and voltage regulation, which is not absolutely needed. I gutted one sensor, removed the bad PCB completely, wired the hall effect sensor directly to the connector pin, and then potted with NC60. Been real solid.
THAW
Foster
23 JL4DrRubicon
Attempting to pot the new version seems like an unnecessary risk; I haven't seen any evidence it fails in the same way (metal contaminated oil intrusion).
alphawolff
california
2021 JLU
i have no idea what potting a sensor is, nor do i think bothering to screw around with it is worth it when the sensor replacement itself takes 15 minutes at most
Terrymo
Terry
2023 JLURXR 3.6 ET
The question is if the later style sensor appears to have a similar failure rate
