K08 Relay orientation - does it matter?
WannFly
Priyo
Atlanta
2021 Rubicon 4Xe, 2026 MOAB
Cyber security
From what I can tell, relay orientation matters. Here is the situation:
While reseating a fuse, I took the K08 relay out and then the o crap moment hit me. I verified few pics on the forum and put it back in, started the Jeep and it did run just fine. However, there are 2 things that happened.
1. I have a nagging feeling that I royally screwed it up
2. My brand new 1 month old NorthStar X2 died the same night - not depleted. Dead. I couldn't charge it beyond 9.6v, took it back to Battery Plus, they tried charging it for 24 hours and couldn't get it beyond 9.6v either. They warrantied it out. Its possible its a bad one from factory, but this is a heck of a coincidence.
I posted for a pic of 4Xe on the 4Xe section of the forum and one of the members shared his pic. The orientation is different than mine. I looked up various pics on this forum and I see most relays including this one is put in every which way.
below is my current picture. note, the number 8474 is pointing to the front of the Jeep, the 2nd pic is from the member that posted the pic, the number 8474 is pointing to the back of the Jeep. Various pics I found that number if pointed both at the front and at the back.
Before I put the new battery in and kill it, anyone knows if the orientation of that relay matters?
Jeep Wrangler JL K08 Relay orientation - does it matter? 1704462918912
From one of our forum members:
Jeep Wrangler JL K08 Relay orientation - does it matter? 1704462994970
Note, some of the other relays are oriented differently as well, but I didn't touch anything else, so not worried about them.
Thoughts?
TIA.
GATORB8
CLT NC
21 JLURe, 06 LJ, 25 HDZR2
I have the diagrams. What does K08 do so I can find it?
GATORB8
CLT NC
Also, are you sure it can be inserted the other way?
WannFly
WannFly
Priyo
Atlanta
Cyber security
I was looking at the diagrams too from 2018, latest I could find. Its the Run/Start relay is all I can find.
B/W, hunting through my phone, I just found a picture that I took before messing around with anything and I indeed put it in the right way
this is how it was from factory
Jeep Wrangler JL K08 Relay orientation - does it matter? 1704467372977
so, my situation is resolved. However, the question still remains since my setup (4Xe JLUR) and the picture from the other forum member (4Xe sahara) is still different.
WannFly
WannFly
Priyo
Atlanta
Cyber security
I am gonna pull it out check now that I have a picture how it was set up from factory
GATORB8
CLT NC
Looks like it can only be inserted one way. Print doesn't matter and is just variation from the relay manufacturing:
Jeep Wrangler JL K08 Relay orientation - does it matter? 1704467786505
mwilk012
2018 Ocean Blue JLU Rubicon
Service
On any relay that CAN be inserted upside down, the posts are staggered diagonally from each other on the inputs and outputs so that it doesn’t matter. You can’t do it wrong.
WannFly
WannFly
Priyo
Atlanta
Cyber security
@GATORB8
Thank you for the diagram. Just pulled the relay, it can indeed go back in a different orientation since there is no PIN 87A. So essentially, if i put it the "other" way it is switching 85 (starter relay control) and 87 (starter relay output) and 30 (starter relay output) and 86 (ground)
@mwilk012 - Thanks for your inputs. See above.
It's probably lack of knowledge on my part on relays, but those switching should matter right?
Jeep Wrangler JL K08 Relay orientation - does it matter? 1704471642662
GATORB8
CLT NC
@GATORB8
Ha, it actually shouldn't.
85 and 86 are the trigger legs. 30 and 87 are the switched legs.
Turn it 180 degrees and they're on the same circuits.
GATORB8
CLT NC
You can just probe it with a multimeter, ground should be 86.
WannFly
WannFly
Priyo
Atlanta
Cyber security
Ha, that explains the various pictures I found where the relays go in every which way. The battery issue was a coincidence after all.
Thanks @GATORB8, much appreciated.
botlfed98
Brandon
NWI & Tulsa
2019 Wrangler
this is strange that you can insert relays in opposite orientation, i also noticed that yours does not appear to have K01 STOP/START & K02 FUEL PUMP like mine which is a 2019
LanceMagnum
New England
2020 JLUR
Some relays have a diode in them to shunt the voltage spike that happens when the coil's magnetic field collapses when turned off - polarity matters in that case.
