ScotM
- Scot
- Jan 3, 2023
- Southern California
- 2022 Jeep Willy's JL 2 Door
I can't seem to find that shunt, but I did see this. Using a 4 AWG battery cable between N1 and N3. I'd really like your Opinion on that?14 AWG/30 Amp is far too small when the PCR and its wiring are removed. N1 powers the entire PDC (fuse box), so it should have a connection that can support at least a couple hundred Amps. [side bar: 14 AWG should probably be fused at 20A.]
The best option (if you can get one) is an N1 to N2 shunt from an eTorque/4xe.
N1 is the direct connection to the PDC (fuse box). The other High Current Fuse posts (N2-N8) are all connected to each other.
With the Aux (ESS) battery ground cable disconnected, N1 (PDC/fuse box) is powered by the CR[an]K (main) battery through its positive cable to N2 to N3 to the AUX (ESS) battery positive cable (if the PCR opens, the connection is broken, thus the reason for removing the PCR fuse, F42).
Removing the PCR and AUX (ESS) battery cables breaks the connection between N1 (PDC/fuse box) and any power source.
