Jscan TPMS ID# issue
Tankeryankeraa
Adam
Massachusetts
2021 Wrangler JLU
Fuel Tanker Tanker
I have a 2021 Jeep Wrangler built after June 2021 I put new wheels tires and tpms sensors (schrader ez sensors 433mhz) I was getting no psi readings I reset the TPMS Fault light and after 20min. the light would come back on with no readings. Sooo I got the sensor ID#'s and manually entered them with JSCAN when I try to manually input the TPMS Sensor ID for Sensor #1 or #2 it changes both to the same ID# for instance if I change sensor ID#1 to (11111111) and then go to sensor ID#2 and put (22222222) it also changes Sensor ID#1 to (22222222) and when I change sensor ID#1 back to (11111111) it changes sensor #2 To (11111111) FYI the 3 sensors with the proper ID# do show correct PSI and then after 20 min I get the tpms fault light with no psi reading for tpms#2 and then all the readings go out. Hope this makes sense and someone has had the issue and solved it. Thanks in advance Adam.
BDinTX
Dallas, Tx
Tankeryankeraa
Tankeryankeraa
Adam
Massachusetts
2021 Wrangler JLU
Fuel Tanker Tanker
BDinTX
Dallas, Tx
I did the exact same thing you did, discount tire swapped my sensors no charge. Hopefully you still have your old wheels (and sensors). Good luck!
Tankeryankeraa
Tankeryankeraa
Adam
Massachusetts
2021 Wrangler JLU
Fuel Tanker Tanker
unfortunately I do not but I did order some Mopar sensors from quadratec and they seem to look like the conti style hope that does it or I'm going to just turn it off all together.
BDinTX
Dallas, Tx
@Goin2drt do you know if the Continental sensors are making it to aftermarket yet? Last I recall even dealerships were hit and miss.
Tankeryankeraa
Tankeryankeraa
Adam
Massachusetts
2021 Wrangler JLU
Fuel Tanker Tanker
BDinTX
Dallas, Tx
Tankeryankeraa
Tankeryankeraa
Adam
Massachusetts
2021 Wrangler JLU
Fuel Tanker Tanker
Yeah I ordered them when I started having problems they're in the center console of the Jeep currently was just hoping to not have to break down the tires again but I think its going to be my last ditch effort.
Goin2drt
Kentucky
18 Rubicon, 17 Grand Cherokee Trailhawk
We have not been able to get our hands on them and as of last week Conti told us directly they were only still selling to dealers their limited supply. The Quad listing is interesting so we sent that to them for a WTH.
Tankeryankeraa
Tankeryankeraa
Adam
Massachusetts
2021 Wrangler JLU
Fuel Tanker Tanker
This is what I got from Quad
Jeep Wrangler JL Jscan TPMS ID# issue 20211209_082919
Jeep Wrangler JL Jscan TPMS ID# issue 20211209_082911
Tankeryankeraa
Tankeryankeraa
Adam
Massachusetts
2021 Wrangler JLU
Fuel Tanker Tanker
I had the sensors I got from Quadratec installed today, the light went out and all sensors started reading with in 5 min. of driving .
Tankeryankeraa
Tankeryankeraa
Adam
Massachusetts
2021 Wrangler JLU
Fuel Tanker Tanker
Chainringtattoo
Grand Junction, CO
2021 Wrangler Rubicon ecodiesel
I Just looked and it says they are out of stock for the Mopar ones.
I saw but says they estimate to ship December 22. I can live with that as I can't even mount the new wheels and tires until the axles show up. Which could be a couple months.
