TPMS Issue/Question?
Ramandeep.singh
Ramandeep
Rockwood, Ontario
2018 Jeep Wrangler Sahara Unlimited
@Ramandeep.singh
Suggest you stop fooling with it "I added some air" ...
This morning, or tomorrow morning, before driving the vehicle, set all psi's to the proper psi and then that is it.
Do this and you should see, psi going up and down a bit but no dash warning lights for low pressure.
Now, when warm weather returns in late Spring/ Summer do as I said once again.
-Remember, don't keep, willy nilly, adding or letting air out-
I get your point. So where would i find the what is the correct air pressure for all 4 tires? Also if the light stays i guess then it has to be fixed by Dealer?
Rhinebeck01
Ormond Beach, Florida
Retired at 55 ..
@Ramandeep.singh
Recommended tire pressure is on a sticker on the door jam. ALL tires get set to the same psi, to include the spare.
Set the psi's in the morning before driving. Drive awhile and the dash light / message will go off.
I seriously doubt your JL has an issue. You are seeing normal / typical behavior.
