rcadden
- Ricky
- May 4, 2021
- Asheville, NC
- 2021 Hydro Blue Sahara Altitude
- Build Thread
- Link
- Occupation
- Marketing
Today's project was to finally bring my 2021 Jeep Wrangler into the 21st century with an LED upgrade. Yes, I know it's a $1.5K option but we shouldn't have to pay $1.5K extra on a $50K vehicle to get LED lights all the way around in 2021 (when I bought my Jeep) OR in 2024. It's ridiculous.
I also *despise* the "robot eyes" look of most of the proper LED headlights out there, and I'm a cheap bastard, so I did some research and have seen many Jeepers on this forum mentioning that they simply swapped the bulbs. Money.
I already had LED taillights due to one of the options I ordered with (also stupid that you can get a partial-LED Jeep) and the front OEM steel bumper that I got came with the LED fogs, so the only thing I was missing was headlights and DRL.
For headlights, I went with these Sealights: https://www.amazon.com/dp/B07KXTP9SY
As advertised, they were plug-and-play, with no issues on my Jeep.
For the DRLs, I went with these @Lasfit (believe they're a forum sponsor?): https://www.amazon.com/dp/B0825M835W
Now, if you'll recall, when I installed my winch, it sits *right* up against my grille, so I *thought* I was going to have to remove the whole bumper. I started with the damn fairlead cover - get the worst out of the way first - and then removed the skid plate and started loosening the 8 bumper bolts.
Which is when I saw that with the skid plate removed, I could actually fairly easily access the four bolts holding my winch to the winch plate. So I figured I could remove those, scoot it forward, and avoid having to remove the whole bumper.
Unfortunately, you still have to *loosen* the 8 nuts holding the bumper on (but you don't have to fully remove it). You can see these retainer clips along the bottom of the grille were *just* a little too long.
The most frustrating part of this realization is that I didn't have to remove the fairlead cover in the first place. I hate that damn cover.
With the grille off, it's super easy. I used this video from [Banned Site]:
3 10mm bolts on each bulb, pull it out, twist and pull. If you look at the socket, there are three notches, but one is *just* slightly longer than the others. Here, it's the bottom one:
And then if you look on the bulb, one of the little half-moon knobs has little extensions on either side:
So you match the extended-moon to the bigger slot, and then turn. The Sealight documentation also notes that the LEDs on the bulb should be facing 9 o'clock and 3 o'clock, so that's also helpful.
The bulbs do have a bit more wiring than the factory halogens did, but it all fit in there pretty snug:
Big difference:
The DRL/turn signals I'm less confident on, honestly (and I plan to reach out to Lasfit for clarification). Accessing them is simple - in the front of the wheel well, there's a plastic trim tree and a 10mm bolt. Remove those and you can just pull the fender liner back a little reveal the TWO bulb slots.
This is where it got confusing:
When I moved the LASFIT bulb to the outer-most, to replace the white halogen bulb, it functions correctly as a white DRL, but now I still have this yellow halogen turn signal. It's not a *huge* deal - the only way I notice is the speed of the flash (halogens take longer to toggle), but it still seems ... odd? I guess I was expecting the inner most "light" spot to light up with the LED as well?
Either way, I kept the LASFIT bulbs in the outer-most slot and it looks great. It's easy enough to access if they tell me something differently.
I still need to adjust them tonight, but that's easily done. I also discovered while I was under there that I can adjust the angle of my fogs, as well. Cool.
Big difference:
- The LASFIT bulbs have both yellow and white LEDs
- The inner-most bulb is a yellow halogen bulb, but from the outside, it looks like a white light.
- The outer-most bulb is a white bulb that looks like a white light.
- There are also two little bitty bulbs (not sure LED or what) that "power" the outer reflector.
