JL nose sits high?
Captain Skip
Skip
New Hampshire
2020 Wrangler JL Sport S
Happily retired
Is it just me or does the JL Sport sit slightly nose high?
rickinAZ
Phoenix
2026 MOAB 392
Interestingly, the Teraflex leveling kit has 2.0" spacers for the front and 1.5" for the rear.
1quick1
Moderator
Moderator
2018 JLUS
I think you can measure the gap between the fender and tire to get an idea but I didn't think mine sat nose high at stock level.
Definitely sits nose low with LoD bumper, skid and winch.
JeepJLU402
Nebraska
2019 Wrangler JLU Sport S - V6 8AT - 30/44
JL is nose up. JLU is nose down. The TeraFlex 1.5” spacer lift is 1” front 1.5” rear spacer on the JL and 2” front 1.5” rear spacer on the JLU.
Captain Skip
Captain Skip
Skip
New Hampshire
Happily retired
OK, then it's just not my eyes. Are there any measurements available anywhere that say what the distance is from floor to the bottom of the front bumper and floor to bottom of rear bumper? My RV is easy, I just put a 4' level on the floor in line with the chassis and level from there.
Dgr401
Dennis
Rhode Island
2020 Wrangler JL Sport S - Granite Crystal
No it is not your eyes, the JL is definitely nose up. It doesn't help when you have a bunch of fishing and camera stuff in the back. The JL's with the leveling kits look much better. I might see about a leveling kit next spring.
Whiskey 13
Northwest Florida
2020 JLUR White Rubicon, Warn 10000 Lb. Winch Syn. Rope, 35X12.5 KO2
The Teraflex leveling kit for the JL 2Dr includes 1” front spacers and 1.5” rear spacers. This leveling kit will give your Jeep an overall lift of 1.5". (according to Quadratec)
Captain Skip
Captain Skip
Skip
New Hampshire
Happily retired
I'm not looking to lift the whole thing, just level it out. The Commander in Chief is vertically challenged (don't tell her she's short!) and has a hip issue that limits her range of motion on her legs so extra overall height isn't an option.
CactusDave
AZ
2020 JLUR, 2017 Porsche 911
My JL has settled to about 1" high in the front, and I'm planning on throwing some spacers on the rear to address it.
Captain Skip
Captain Skip
Skip
New Hampshire
Happily retired
I took a look at the Terraflex spacers. How difficult of an installation is putting the spring spacers in? The instructions tell you to disconnect or loosen everything on the rear end. Is this something doable in a homeowner's garage or does it need to be professionally installed? Can it be done with spring compressors or is that the only way to do it? I'm not a novice at working on vehicles, I've rebuilt engines, changed shocks, driveshafts, axles, etc. Just trying to map out a strategy.
AlexJeepVB
Alex
Virginia Beach
2019 JL Rubicon 2.0T eTorque
Very doable in your garage. Just need a few good jack stands and a good floor jack and you will be good to go. Just jack jeep up high on the jack stands then lower axel with floor jack and springs will fall right out. Even tho the instructions say loosen all of the control arms if you are only doing a .5 spacer I don't think that is super necessary. Thinks it more them covering their ass if your bushings wear out.
wchevron
RI
2021 JT, 2020 JLU
My JLU looks like it's nose up but when I measure from the ground to the wheel well, the rear is about an inch higher. Think my driveway might be pitched a little, although it looks pretty level.
The Last Cowboy
San Antonio, TX
2020 JL Willys 2 door
After 5k miles, mine has definitely squatted a little. Thought it was me, but I was behind a 2 door Sport JL today and noticed the same thing. Reminds of an old CJ7. Don’t know if I will go with a level kit or a set of JLUR Springs. I have Rubicon shocks, so I shouldn’t need spacers for them.
