Jeep JLU pulling to left
Mreservices
Michael
WV
2021 JLU High Altitude and 2024 2-Door Rubicon
Looking for some help on a problem I'm having with my 2021 jlu.. Just had an alignment done because it was pulling To the left period Everything was aligned and the steering wheel is straight however, when you Let go of the steering wheel The Jeep starts pulling to the left. It doesn't matter if you're on the right side or left side of the road Crown or on flat surface. It just started doing this over the past several months. Everything is square but I do not know what's going on. Any thoughts on what I can check? Try not to take to a dealership but may have to.
Old Dogger
Bill
Cave Creek Arizona
Hanging Brake caliper.
Mreservices
Mreservices
Michael
WV
I just took them apart the day before I went. I literally had just taken pads off to check and applied some lubricant. To make sure they were free floating. Easy enough to take the tires off and check that. Any other thoughts before I get into that project of things to check? I appreciate everything.
Old Dogger
Bill
Cave Creek Arizona
Try rotating your tires. If that doesn't help, then remove your steering stabilizer and see if that helps. How much positive caster do you see on your alignment sheet? What are your camber readings? Has your wrangler been lifted?
rickinAZ
Rick
Phoenix
2026 MOAB 392
My 2021 had a pull until I switched to a pass-through design steering stabilizer. @Old Dogger 's idea about (temporarily) removing it should isolate whether that is the issue.
Mreservices
Mreservices
Michael
WV
Jeep has a level spacer lift in the front and that's it. Caster per the report was 4.3 on one side and 4.8 on the other side. I know that's low and I need to likely get some adjustable lower control arms at a minimum. Thing is this has not been pulling up until a few months ago that I noticed. It wasn't an issue after the lift several years ago. Something that's new. I will definitely check the brakes, rotate tires and if that doesn't do it try the steering stabilizer removal. I appreciate everyone's input. At least it gets me some things to try. Thank you again.
