Is this right?
Eischman
Hortonville, WI
2021 Rubicon Unlimited
So After installing a Teraflex 2.5 spacer lift on a 2021 Rubicon I noticed how close the bump stops are to touching and started wondering if I should not have installed the bump stop spacer along with the Falcon Jounce bumpers?
Nowhere in the instructions did it say NOT to!
Is this right, it sure doesn’t look right to me at least.
Jeep Wrangler JL Is this right? ED08107E-1B2F-49E0-8EFE-5F650D206BF3
Jeep Wrangler JL Is this right? 579DFED6-6447-42B6-8962-E80DD3484B62
Jeep Wrangler JL Is this right? 9FC50479-7E43-46C0-ABE3-6EF8CAAA6348
Jeep Wrangler JL Is this right? 2E31C0F7-A373-4823-AF23-EA1E0DDA506F
Stuckinthesand
CJ
NJ
2019 Wrangler Sport S
Definitely not right. The bump stop is there to stop your tire from getting into your fender. You’ll have no articulation with the way it is set now.
Eischman
Eischman
Hortonville, WI
That’s what I thought, why in the hell would they not had said anything in the instructions. Well, I guess I can cut 2” off with a hacksaw blade, because I’m sure as hell ain’t going to take it all apart again ?
word302
Oregon
JLU
Not surprised
Eischman
Eischman
Hortonville, WI
Right? Why would you have a “NOTE” before you continue to read the Falcon instructions and then never tell you to not use the spacer!
Well anyway, I think that now I know the front end and I’m not installing new track bars and steering stabilizers and I know what to disconnect unlike the first time it should not take more than two hours to correct it, I’m just debating which one goes, the spacer, or put the stock bump stop back on?
19 JLUR Bright Whit3
Baba Yaga
NJ
www.youtube.com
Retired LEO
My $.02. Remove the TF bump and put back your stock one.
Declaimer: Do your own research, don't do what I would do. LOL
Tharris
Travis
Murrieta CA
2018 Rubicon 4dr (JLU) Sting Gray
If those soft stops compact alot it may be to design. The bump stops seem rather tall for a 2.5 inch lift. I don’t think you would even need new bump stops with a spacer lift.
Eischman
Eischman
Hortonville, WI
I stretched the springs and pulled out the Falcon and reinstalled the stock one, it was the easiest to do without taking springs completely off, took about an hour.
