Is F.A.D. still a thing?
Melchior
Mel
Los Angeles
Toyota GR Supra
Is Jeep still including the Front Axle Disconnect on current wranglers? How do I know whether mine has it or not? I have a ‘24 3.6 Manual Rubicon
Philly_
Dallas / Detroit / NYC
2022 JL Rubicon
I’ve seen it randomly excluded from some builds, so I couldn’t tell you for sure.
Easiest way to tell would be to look at your front axle, and on the passenger side there will be a box on the axle tube. If that has wires plugged in to the back side, you’ve got it. If you don’t have those wires, it has the block off plate and no FAD.
Melchior
Mel
Los Angeles
Toyota GR Supra
Ahh, gotcha! Thanks for the heads-up on the wires! Checking now ! ?
bwags87
Tennessee
2024 Anvil JLUR
I believe all 2024 Rubicons and Willys have the FAD removed. I have a 2024 Rubicon and do not have the FAD.
Jtphoto
Thunder Bay ON
2022 Rubicon Xtreme Recon Granite Crystal
So far the only model I’ve see the FAD on is the Sahara. Even the Sport no longer has a FAD.
jellis4148
Missouri
2019 Jeep Wrangler JLU Rubicon
I work at a Jeep dealership, and it looks like they removed the FAD and went to CV joints on the front axles. I am not a fan of the FAD, but I do like it because I can run my caster at 6 and not get any vibration from the front driveshaft since it isn't spinning. I haven't driven or talked with anyone in a 24 that's done a lift, but I can only think not having FAD will cause a vibration.
Jtphoto
Thunder Bay ON
That’s crazy. I’ve never seen so many changes to any other car model during its life cycle. No more diesel, no more v8, no more etorque etc etc
There are very few models of any vehicle that have more then a 3 or 4 year life span let alone 10 years like Wranglers.
Philly_
2022 JL Rubicon
I think the only way we could all really benefit from the FAD delete from factory is if they changed the axle housing as well. The big hole they have in there for the electronics and whatnot is still the weak point, even with the block off plate. If I have to have the hole, I'm happy there's at least a purpose for it.
Even though I have it, I still run my caster close to OEM at around 4.5-5 because I have the full-time transfer case and an aftermarket drive shaft. If I run it near 6-6.5, as recommended, I could still end up with vibrations whenever I am in 4-auto. Personally I don't mind the way it drives with less caster. Feels like a Jeep!
Jtphoto
Thunder Bay ON
You’d be better off with free wheeling hubs then a FAD.
Jtphoto
Thunder Bay ON
Jeep just proved the fact that the FAD was never needed on the JL at all. It was never an issue on the previous version Wrangler JK and it had the same factory caster spec.
autotragic
the cornbelt
'21 JLR 6MT
My working theory is that they needed everything they could get due to CAFE standards. Either changes were made elsewhere or cuts to gas engines were enough that they were able to remove the FAD.
azwjowner
Phoenix
Mine is that they want to pass the IIHS small overlap crash test without rolling over, and this will affect how the axles and wheels move in the crash.
