Instrument Cluster Swap
Gregj
Greg
West Texas
About $110. Quick turnaround too.
Gregj
El Zilcho
Max
San Diego
2018 JLU Sport, Rubicon axles
That is strange, I heard ~$100 from others too, but when I asked for a quote from them, they replied with $200 quote.
Gregj
Greg
West Texas
I had mine done about a year ago, so they may have raised the price.
Gregj
singledaddio
Nathan
2018 Jeep JLU, 1990 Dodge Dakota
So the upgraded cluster will track your pitch and roll angles without any additional sensors?
Gregj
Greg
West Texas
Yes, it has that page in the cluster and will also show the steering angle.
Gregj
singledaddio
Nathan
Gregj
I knew it had the page on it, wasn't clear that it was equipped to actually use that function. I'm not very tech savvy, but I might try this. Thanks!
lzaffuto
Lucas
Holly Springs GA
2020 2 door Sport S Sarge Green
I'd like to do this, but I think I'm going to wait a bit longer to see if an aftermarket all digital cluster gets released like what is available for the JK. Dealing with the odometer seems like a pain, and I definitely don't want any flags coming up in a carfax on my VIN or anything.
El Zilcho
Max
San Diego
Its less than $100 to reprogram, so no red flags :)
Aburley8
Andy
buckeyes1
2022 Wrangler Unlimited Willys
Found a basically new (19 miles) Rubicon instrument cluster on eBay for $100, only issue it was a KPH cluster. I realized that all of the digitals in the cluster (Speed & Odometer) could be swapped US/Metric via Settings in U-Connect menu.
Found the following video, which is for new US Speedo Tach/Speedo dials
After watching it I realized I could either A) Buy new replacement dials, or B) swap my current dials into the KPH speedo cluster.
Long Story short, rolled the dice and so far, a winner.
ISSUES:
*JL Sport 3.5 Cluster Tach dial and Rubicon 7” Tach dial are shaped differently and the JL Sport doesn’t have the Tach bezel. Decided to keep eBay Tach dial and swap the Speedo dial which was an “issue” bc of below.
*The Original Cluster markings were Orange, the eBay cluster markings are Red. Not sure if this is the case in all MPH vs KPH or Sport vs Rubicon clusters but I am OCD and do not find it that noticeable when lit, nor a dealbreaker for me.
*Odometer reading - have already made an appointment with a local shop to reprogram to match actual mileage**
**For any & all trolls whose initial thought is “that’s ILLEGAL”, I’ll mention briefly that a) I practice law & understand the law(s) in Arizona surrounding this mod. B) I am not making this mod, with any intention to lower or ”roll back” the actual miles on my Jeep, and have made arrangements for the odometer mileage to be corrected. The only reason I mention the eBay Cluster as being “basically new” was to reference the condition.
ATTACH=full]217176[/ATTACH]
so I have a question, I just purchased a 22 Willy’s and I have that base cluster, can I order one from the dealership, the all digital one? And it will work? I went to a dealership today and the lady in parts didn’t even bother to look on the computer
El Zilcho
Max
San Diego
Yes. It will work, at least it worked for mine and many others. Dealer or some other service will need to put correct miles for the odometer.
Gregj
Greg
West Texas
Should I just go into the dealer then? Do you know the part numbers?
The dealer will likely not want to get near this swap. I looked up the part number on the cluster I bought and it is $284 at Allmoparparts.
I would suggest you find a Jeep equipped like yours except with the upgraded cluster (I believe it is part of the technology package) and use the vin from that Jeep to order a cluster. If you use your vin you will get one just like the one in it. There are a LOT of different part numbers.
Gregj
