Instrument cluster not working
army_chief
2018 Jeep Wrangler JL
I have a 2018 Wrangler JL and I started it up the other day and the instrument cluster is completely out. No speedometer, tachometer, fuel, lights anything. I checked the fuse that I believe could be the issue and it seemed fine.
In researching I noticed it could possibly be the aux battery. The engine start/stop feature does not appear to be functioning either (the button works for it but the vehicle won't start/stop like it normally does). My plan is to test the aux battery but wanted to see if anyone had any insight on this issue.
I was looking into the Can C Bus but my head started hurting trying to figure out the wiring etc.
I tried finding a replacement cluster just in case it is that but of course I couldn't find the original cluster available anywhere.
Any sugguestions, easy ways to test things. I'm open to all input. Thanks!
ForgottenTaco
CT
‘23 Sarge Green JLU Willys
Isn’t there a recall or something in certain gauge clusters?
Derrick20JL
Derrick
CANTON, GA
2020 Willy 2 Door
Its probably the cluster that has failed. I work at a dealership and I have 3 different jl that are waiting on back ordered clusters. The only clusters that are coming in right now are ones that have the recall.
army_chief
I noticed it was impossible to find one to order. If I was able to come across one do you know if it is plug and play or does the dealer have to program it. I've heard people say they caused their vehicle to go into limp mode because they tried swapping their clusters.
Derrick20JL
Derrick
CANTON, GA
2020 Willy 2 Door
from what i understand they have to programed via the vin and we dont even program them in house. that is all done by the rebuilder
Gregj
Greg
West Texas
There are used ones available on EBay, the mileage will be wrong but you can get that corrected. I swapped my cluster out years ago and it has been fine.
Gregj
MitsJeep
South Carolina
2018 Black JLUS
Call United Radio. They will fix your cluster. I had the same issue.
