Odometer cluster not working
Mdobbins
Marty
North carolina
2018 jeep wrangler
I have a 2018 wrangler with around 70k on it and everything on the odo
DaltonGang
Doesn't Play Well With Others
Two things come to mind.
1. Check to see that all fuses are seated fully.
2. It could be a bad aux battery. This could lead to electrical gremlins, as well as draining of the main battery.
MitsJeep
South Carolina
2018 Black JLUS
OP, can you provide a little more info? what is it doing? Is the whole thing dead with no power? Is is just the screen black? What is going on with it?
Mdobbins
Marty
North carolina
2018 jeep wrangler
Nothing on cluster works jeep runs fine. Its like the cluster went bad or lost power ive checked fuses they are fine
MitsJeep
South Carolina
2018 Black JLUS
I would check your CANBUS behind the dash just to see anyway. You could also have bad battery issues with both aux and main. You need to replace both of those at the same time.
Your cluster could also have failed. See United Radio if so and they may be able to assist you if you speak with them over the phone about your specific issue.
Mdobbins
Marty
North carolina
2018 jeep wrangler
Is the Canbus the green connector behind glove box if so had it replaced was throwing all kinds off losing communication codes
Bob Burd
Bob
San Jose, CA
www.snwburd.com
Not batteries or canbus block. Most likely display needs replacing. Could just be the LCD screen. There are other threads here how to do this.
MitsJeep
South Carolina
2018 Black JLUS
There are multiple parts to the Instrument cluster. Both the screen part, but also needles. From OPs description, nothing is working in the cluster- so thats why I suggested a base check of batteries and CANBUS since those can cause issues in weird ways.
The entire cluster can fail, but also just the screen can fail.
