Installing USB power for a trail camera?
Jbdell100
Conroe
2019 Wrangler
Has anyone ever tied into the power leading to the vanity mirror sun visor to add a USB for a trail camera? Or are there some other power wires that I can tap into easily to run a USB connector near my rear view mirror for a small camera?
etoften
Eric
Washington NC
2021 JLU Willys
You can use a garmin power harness if you don't have a tazer permanently installed. That's how I am powering my dash cam.
Terrymo
Terry
2023 JLURXR 3.6 ET
@wibornz i think. Check his Wolfbox camera install thread somewhere toward the end
Ratbert
PNW
2022 AEV JL370 JLURD
Software Engineer
I'm trying to understand how a Tazer would impact a power harness.
etoften
Eric
Washington NC
2021 JLU Willys
The garmin power harness plugs into the obd2 port. Isn't that where the tazer goes? Excuse my ignorance if i am wrong. I obviously don't use a tazer.
Ratbert
PNW
Software Engineer
No, the Tazer doesn't plug into the OBD2 port.
There are much simpler options than plugging into that port, but they seemed to want something near the rearview mirror.
Pape
Quebec
JLU Sahara
Usb standard is 5v therefore anything supplying v5 will do the trick. I guess next question is on all the time or with the key :)
AndySpill
Andy
Pittsburgh
2018 JL Sahara
I've done this, only the appliance I powered doing this runs on the same 12 Volts as the vehicle's electrical system and doesn't use USB connections.
I think you'll need something like this to step the voltage down to that consistent with USB gear. Otherwise the vanity mirror wires can serve low amperage draw devices that don't require electrical current much after the vehicle is shut off.
https://www.amazon.com/Vehicle-Direct-Charger-Charging-Converter/dp/B07H6YZ9XS?th=1
Wabujitsu
Sarasota, FL
2021 JLUR, 2020 JLU Sahara
Retired US Army
Has anyone used this in a Wrangler? Doesn’t list Wrangler specifically in the comparability list. Would be a great solution for my dashcam connection.
That one is not compatible with the plug coming to my OEM mirror (2021 JLUR). Mine is a 4-pin connector. Let me know if you need a photo of the plug.
68jcode
Adam
MA
2021 Jeep Wrangler
I haven’t pulled mine apart yet, but saw some other threads and maybe YouTube video showing 10 Pin. I will pull mine apart tomorrow morning to see what I got. I do have the auto dimming mirror, do you?
Wabujitsu
Sarasota, FL
Retired US Army
Yes Adam, mine is auto-dimming. Photos attached; four-pin plug (3 pins and a hole, only 3 wires in the harness).
Jeep Wrangler JL Installing USB power for a trail camera? IMG_3484
Jeep Wrangler JL Installing USB power for a trail camera? IMG_3489
There’sOnlyOne
Greg
NW Georgia
2021 JLUR
https://a.co/d/00YIDNkv
This is a whole cam system. It has a pic of the pin. I see alot of 10/14 pin for Jeep but not seeing any 3 pin. Even in eBay. Wonder if the 3 pin will work with a 10/14 pin? Some of the vendors on Amazon show a link to ask about compatibility. Guess you could reach out and see. If you do find something please post in this thread. I'd like to use one myself. There are several hardwire options but of course you have to run those up from the dash area.
I just wish I could cut my rear view mirror arm in half or by 2/3 to get the mirror higher and out of my direct eye sight. It's in the way for me, a freakin blind spot. I forget his handle but one well known member has a Wolfe rear view mirror camera mounted in his dash and did away with the factory mirror fo this reason and since his spare tire blocks his rear view anyway. I might do that at some point.
Jbdell100
Jbdell100
Conroe
2019 Wrangler
Thinking about seeing if I can tie into some of the lights above.
